Question about Tomtom ONE GPS Receiver
Auatomobile adaptor not working
The automobile adapter for the cigarette lighter for my Tom Tom keeps going on and off? Is there a fuse in it? or where can i purchase a replacement part.
  • 124 Answers
Thanks for letting me assist with your problem. Does your vehicle have another lighter or utility plug? If it does, try and plug your One into a different one. If you only have one, try it in a friends vehicle and see if the problem continues. If it stops cycling on and off, then it's the lighter outlet in your vehicle. If it doesn't then it could be the plug on the vehicle adapter. If my help has been satisfactory, I'd appreciate a rating. Thanks for using FixYa.
Posted on Jan 29, 2009
I have a 2001 toyota echo, my radio and clock dont work. They stop working when i plugged in my gps into the cigarette lighter. This has not happen before, i always plug my gps into cigarette lighter to...
check fuses to see if blown or try another adaptor in the socket lighter to see if it works if it dooesnt then the fuse if it does work oh boy a long and wonderous journey awaits you i am only joking it could be serious but check fuses first its easier
Jan 07, 2011 | 2005 Toyota ECHO
I just got my first cb and am trying to install it. I have connected the red wire in the fuse box( to the radio) and grounded the black wire. turned the car on and I cannot get any power to the CB, but the...
Take a deep breath and start over! The best way to power this little radio is probably through the cigarette lighter or 12vdc accessory jack. It is simple and straight forward and no fuse box or negative ground wires to worry about. Go the Radio Shack, purchase an adaptor (cig lighter type) and hook it up to your radio wiring being careful to watch polarity. You may have to have your ignition on to run the radio, but that is much safer that maybe blowing up the unit.
Unless you are running a larger more powerful unit or an amp, there is no added benefit to hooking the radio into the fuse box.
Dec 16, 2010 | Cobra 19 DX IV CB Radio
Have tom tom for car,need to wire it up to m/cycle
I've wired my tom tom for use on a motor bike.
you CANT run 12v straight into the tomtom, you can see on the cig lighter plug it has a 5v output.
So I bought cheap lighter socket, it looks like plastic tube with the cable running out of the back.
So the wires run from the battery (via an in line fuse) to the cig adaptors, these are hidden in my side luggage bag to keep dry and up to the tomtom. job done
Apr 20, 2009 | Tomtom ONE 3rd Edition GPS
Cigarette lighter adaptor becoming very warm in use
the lighter receptacle is dirty and needs cleaning
Mar 23, 2009 | Tomtom ONE XLS Car GPS Receiver
Automobile adapter not working
yes there is a fuse on the adaptor end
unscrew it and put a new one in.
Jan 29, 2009 | Tomtom ONE GPS Receiver
Dead
Does the cigarette lighter work in the car when you press it in? Does it get hot? If not has the fuse blown for the cigarette lighter?
If that is supplying power you may have a fault in the cigarette lighter to Tom Tom lead. Carefully check the fuse (one of the six bumps) in the plug and make sure it is still intact (use a meter).
If the fuse is OK then the lead itself may be faulty and probably needs to be replaced.
HTH
Peter
Jan 26, 2009 | Tomtom ONE GPS Receiver
DC Adapter for laptop doesn't work
there is nothing you can do appart from replace the car adaptor or check that the cigarette lighter is recieving power to the socket
regards
Nov 24, 2008 | Dell Inspiron 6000 Notebook
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
Tomtom ONE GPS Receiver Logo
76 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
