Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Everything that I print is faded with lines through it.
I have changed the ink and cleaned the head and it still is faded.
  • Anonymous Jan 30, 2009
    my printer wont stop printing those silly lines and i cant get the printer head out to clean it
    can anyone help
This is the same problem I have with my Kodak ESP-3 printer. Even after installing new cartridges I had faded color and lines (banding) thru the picture. I found many people wit the same problem and found out that Kodak had a very large batch of defective printer heads that were sent out with the ESP and 5500 series printers. I called Kodak customer sevice, the automated systym even has a number to push for the problem printers. Then you get a live tech person who runs you thru some diognostic steps. They are well aware of the problem and will send you a new printer head and cartidges for free and they pay the postage.
Posted on Jan 30, 2009
3 Suggested Answers
SOURCE: black ink won't print.
My printer worked fine since April but this week, I could not print. Thought my ink had dried up although I only replaced it just before christmas.
Bought new ink, installed it and still nothing. Calibrated, cleaned etc. etc. re-installed the disk to do maintenance and after several frustrating hours trying to fix it, I called my local Staples, the store at which I purchased this printer to ask for help.
First of all he said, what printer is it, black or white. I responded white to which he said okay that identifies the model for me. I am sorry to tell you that Kodak has acknowledged a problem with their print heads and have sent us several to replace the faulty ones. I said lovely, I wished I had known that several frustrating hours ago and he responded that it was his understanding that Kodak was going to announce this to all registered owners via a bulletin. Unfortunately I did not get it so wasted a lot of time. He requested I come in and get the new print head or if need be bring in the printer and they would install it for me. I am pleased with the store's response but not very happy with Kodak's lack of committment to get the word out.
Hope this helps.
Posted on Jan 15, 2009
  • 518 Answers
SOURCE: printer not printing properly
are the contacts on the cartridge clean as that will effect print quality
Posted on Jul 07, 2010
I have a Canon PIXMA MP250, and it's printing black and faded lines alternatively. (one line black, one line faded black...), sometimes involve blue too.. Anyone can help?
First, are you running low on those ink colors? If not, possibly print cartridges need cleaning. If printer has separate print heads, they made need cleaning.
Lastly, print head(s) may need replacement.
Dec 08, 2014 | Canon Pixma MP250 All-in-One Color InkJet...
I just changed the ink cartridge and now the printing is faded.
try doing a head clean that should push the ink through the attached print head you may have to do about 3x head clean to push ink through print head
Jun 21, 2011 | Epson Office Equipment & Supplies
Print is faded. I just replaced the ink jets.
You said you just replaced the ink jets. Did you clean the print heads? Here is Link on Web. If you find this helpful pls rate me. Thanks
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
How to improve print quality
Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print
head. You can start the cleaning process manually if needed.
Clean the print head and ink cartridges if you get a horizontal line in
the text or graphics on your printed pages. You can clean Black only
or three colors at a time (Cyan/Yellow/Magenta), or all four colors at
once.
Cleaning the print head consumes ink. Cleaning too often uses ink
unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause
permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press or to select Cleaning.
Press Menu/Set.
3 Press or to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished,
the MFC will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved, call Brother Customer Service (see Brother
numbers on page i).
Jan 11, 2010 | Brother MFC 210C All-In-One InkJet Printer
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
Faded Lines on my prints from my Photosmart express C4280
try using isopropyl alcohol and a lint-free cloth and carefully clean the print heads on the printer itself. Failing that, consult the manufacturer.
Aug 23, 2009 | HP Photosmart C4580 All-in-One InkJet...
Faded printing
Use the ink head clean proceedue(Software) outlined in your manual,until it quits fading out.
Your Manual, Link below, if needed. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=12764
Mar 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Won't print but few lines til black fades out
It pretty much sounds to me like you have "outdated" or old cartridges. Are you using the photo setting to print photos? Before you purchase more expensive cartridges do a head cleaning! Good luck.
Dec 16, 2008 | Dell 924 All-in-One InkJet Printer
Black line down the page
Is the line on the front of the page or on the back? If on the back, you need to clean the platten which is the piece of plastic under the paper.
If its on the front, and you say "It lools like a rubber cover may be missing off of one of the rollers", could you upload a picture of this roller? I don't recall any covers on rollers in Canon printers.
Try this, print out a blank page. If line is still there, print out 10 blank pages. If line is still there and has not faded, this is unusual and may need servicing. There may be a problem with the encoder strip (it's a clear plastic strip with black lines running the length of the printer slightly behind the head), Try cleaning it on both sides with a little windex on a q-tip. It's delicate so be careful.
If the line looks faded after printing 10 blank pages, some ink has dripped onto something that is contacting the paper. This could be a roller, the bottom of the head carriage or even a hair or piece if dust that is stuck in the machine or on the bottom of the head. In this case, I would recommend cleaning everything. Revove the head (tell the machine you're going to replace ink, and when it moves the head into the centre position unplug the power cord.
Remove the head and clean off any dust or hairs on the bottom. Run a Q-Tip along the bottom of the carriage assembly wherever you can. Clean any accessable rollers. If you can get at it, clean the wiper on the purge unit (the unit the head sits over when it is parked), as well as the seals.
Reinstall the head and ink, close the lid, power up and retry printing.
I hope this helps. If not, there could actually be a fault with the printhead or one of the circuit boards
Dec 28, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
287 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
