Question about Kenmore 95002 / 95004 Electric Kitchen Range
My Kenmore glass top range, model 665 95802000, left front large burner is out. I tried replacing it with a new one...didn't work. Tried also replacing infinite switch for that burner...still doesnt work. HELP!!!
  • 2 more comments
  • Anonymous Jan 30, 2009
    large element won't work.
  • Anonymous Mar 01, 2009
    right rear burner not working.
  • Anonymous Apr 14, 2009
    elect.glass top burner front right has 3 different setting the middle small setting does not work
  • redsmiley Apr 15, 2009
  • 29 Answers
SOUNDS LIKE YOU MAY HAVE A WIRE BURNED. CAN YOU USE A MUTIMETER?
Posted on Jan 29, 2009
Spectra range. Both large burners diagonal across from each other have stopped working. Is this fixable. Other burners OK.
yes it is is this glass top type ? very easy to work on and get parts for , first thing unplug unit from walll, there are two screws near the front of the oven.to the left and to the right of the oven.near the top front . once you remove the screws lift the top up and support it with something look at all the wires and you will see one that has been burned , the only wire you can use inside of this area is what they call glass wire , so it will take the heat . I am almost positive this is just a burned wire , replace the burned wire with glass wire and you should be all set, keeping in mind move the wires away from the burners this time so it wont happen again
Jul 26, 2011 | General Electric Kitchen Ranges
Dual element left front
call a repair service locally possibly he got the wrong element
Jan 20, 2018 | Kitchen Ranges
Large right front glass burner snd surrounding
The item number for this through repair clinic.com is 770583 with a cost of 374.00 Most costly part of the stove. Sorry wish it could have been better news.
Mar 09, 2010 | Kenmore Kitchen Ranges
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Hi, my GE glass top oven has a bridge burner that won't work.
the bridge burner is 99 percent chance that it is blown. turn the power off and take that burner out and see if you can see a break in the burner. then replace.
Nov 30, 2008 | GE Spectra JBP78 Electric Kitchen Range
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on...
If the burner is scorched or pitted, go ahead and replace it. New burners can cost anywhere from $10 to $40. Otherwise, check the burner's electrical connections to make sure there is solid contact. Jiggle the burner in its socket. If it is loose, then remove the burner—most just pull out of the electrical socket, although some are mounted with a screw. (Always unplug the range before removing a burner.) Slightly spread the two terminals apart for a tighter connection. If it still doesn't work, then replace the faulty burner with a functioning burner of the same size. If that burner works, then replace the bad burner with a new one. If it doesn't, then inspect the electrical socket for damage. If it's charred, replace the socket. To do so, remove the screws that secure the socket to the range and then unscrew the range wires. Attach the wire connections of the new socket to the range wires and reassemble the burner.
Aug 19, 2008 | Kitchen Ranges
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Kenmore 95002 / 95004 Electric Kitchen Range Logo
731 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
