Question about Panasonic PV-DV400 Mini DV Digital Camcorder
Incompatible Tape I was watching already recorded tapes in the camcorder, when all of a sudden I put one in and it said incompatible tape and refused to play, rewind, fast forward, or pause. I tried all the tapes I have and none work, when before at least one was working! Please help?? How can I fix this?
  • pSouper May 04, 2009
    yup -i too have this problem. out of the blue, my panasonic nv-gx7b mini-dv camcorder refueses to do anything with any tape i put in. instead it shows "incompatible tape" on the screen for a few seconds then plays dead.
    I have pressed the reset button as per the instructions but to no avail.
    if anyone can help or has a proven solution I'd be more than greatful.
    cheers, jn
If the camcorder cant play or record, how do you then use a cleaning tape?
Posted on Jul 29, 2007
  • 73 Answers
Try a cleaning tape first - best not to rewind the cleaning tape because it will put back the crud previously removed ? into your heads and guides ( last tape to play is prime suspect ) ; - - digital heads wear faster than analog so a new set of heads is next possibility but if the cleaning tape works . . . retire your library soon as possible .
SOURCE:
I have an old technics su-z22 amp and a denton tape deck with an it seems an incompatable record out socket from the amp and two rca sockets on the tapedeck how can i marry the two up
Having looked at the back of the model referred to I see two sets of RCA sockets for the connection of two tape decks. So I don't know what you mean by incompatible record out socket? There is a 5 pin din but you can use the two RCA sockets to connect the tapedeck. If you have a good quality RCA lead it should record and playback. You can in fact connect two tape recorders to this unit using the RCA sockets.
Apr 11, 2013 | Audio Players & Recorders
Sony camcorder
The tape is locked by a pin on the cornerside, check the locking hole on tap.
Jul 18, 2008 | Sony DCRHC90 Digital Camcorder Extra Gear...
C:32:23
This is a common problem with alot of Sony CamCorders...The solution is simple.....GIVE IT A WHACK!!!
Seriously, Take the battery off the device, Give the camera a smart "smack" on the tape side of the unit and power it back up.
works in 90% of cases!!!
Sep 22, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
How do I erase a tape alreday recoreded so that I can reuse the tape?
Before you insert the already recorded tape make sure you close off the small square hole with the moveable tab(often green or red colored).After inserting the tape rewind it to the point where you want to start reusing the tape ,set in camera mode and hit the record button .
May 13, 2009 | Canon ZR100 Mini DV Digital Camcorder
Hi there Guys! Problem with Sony Camcorder DCR - TRV230E
Stuck sensor. Sounds silly but smack it.
Hit your camera several times with a flat hand (bottom, tape side). Its strange but it solved it for a lot of people. Firmly smack the bottom and then put the battery back on and give a it a shot.
Feb 02, 2018 | Cameras
Recording from the Mini DV to VHS Tape
Mini dv is a digital recording and VHS is analogue so they are incompatible. Does your camera have an analogue output? That is a lead that ends with something like RCA plugs or a Scart plug. Then you can feed the signal into a VHS recorder.
Aug 23, 2008 | Canon ZR45MC Mini DV Digital Camcorder
Canon Elura 65 Camcorder Refuses to Load Mini DV Tape
Try a different tape in case the take up isn't working in the previous tape.
Clean the tape heads with a tape cleaner in case there is buildup on the pinch rollers causing the tape to jam or slip.
If those solutions don't work, you should take it into a repair shop to have a closeup view as to what the problem is unless you see something obvious like a spring broken or loose or a bent piece or foriegn objects in the deck.
Aug 12, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Problem with Panasonic NV-GS3 camcorder
use cleaning cassette , before a brand new blank tape ( may have a worn or damaged tape in your library ) ;
Jul 29, 2007 | Panasonic NV-GS17 Mini DV Digital...
Image and sound problems at playback
your tape guides are out of calibration on all your pre - recorded tapes , or they are out of adjustment ( maybe even loose ) now ; - - put your camcorder close , next to your ear ? and . . . listen ! to a new tape in play mode - if you hear a fluttering sound like a deck of cards being shuffled softly , the camera is damaging all your tapes and needs alignment ;
Jul 28, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
Panasonic Nv-GS3
I have the same problem, i was just using my camcorder and when i changed the tape, it says incompatble tape and now it wont play or record at all. It has happened to me today.My friend told me to leave for a while and try again. Hi C8dee, is your camcorder working, any updates, did you find a solution. [email protected]
Mar 30, 2007 | Panasonic NV-GS3B Mini DV Digital...
Panasonic PV-DV400 Mini DV Digital Camcorder Logo
267 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
