HP Pavilion a1330n (EL466AA) PC Desktop Logo
Posted on Jan 29, 2009
Can a cd be repaired to be readable?
I have a cd with a lot of several data files that apparently has been scratched and wont read? Is there anything that can be done?
Anonymous
Level 1:
  • Contributor 40 Answers
  • Posted on Jan 29, 2009
Anonymous
Contributor
Level 1:
Answers
40
Questions
0
Helped
10664
Points
92
A disk can be refinished fairly cheaply. In my area Blockbuster does it. Call your local computer shops and such im sure someone has a refinisher.
2answers
Error reading coreldraw x5 file
If you are reading off a CD/DVD make sure it is clean and there are not and spots or scratches. If you are reading from a file off a server then you could easily have a corrupted file. Check the file length and make sure it is not zero. Anyone else?
6answers
I have plastic cover migration to my CD's. Slight problem is removed by alcohol; but some discs will not clean, and the disc is not readable. Help.
Try cleaning CDs under tap water and dry them thoroughly with a soft cloth. May seem weird, but this often clean the CD better tan alcohol.
Ensure CD have no paper label on top before washing them.
tip
HOW to Recover Data from Scratched CD's
HOW to Recover Data from Scratched CDs
All CD or DVD are always get some scratches when you use or even if your carefully using it,there's time that accidentally make some scratch in it.this tip is a painless techniques on how to create a full working CD from the scratched one. I have personally tested this and had fixed a CD that would not read data at all. This tip works best with small unreadable scratches, as some hard scratches are too deep and loose the data permanently.
Requirements:
1:Alcohol 120% software [or similar]
2:Cooking oil
3:Small piece of cotton
4:Dry cleaner paper
Follow this simple steps to fix a scratched CD for repair purposes:
In step one you must do some preparation work on the CD. Begin by wetting the cotton with water. Begin to clean the CD in a vertical motion; three firm wipes shall be sufficient. Dry the CD with the dry cleaner paper.
Using another piece of cotton, apply oil to the CD surface. Be sure to do this with caution and not overuse oil. After a through cleaning, dry carefully. Particles from the oil will stay on the micro surface of the scratch. It appears that the oil helps the laser of the CD/DVD driver
to read the surface again.
After downloading and installing Alcohol 120% software, run the program and select to create an ISO - image making wizard. Attempt to read the CD drive and test if the program can read the Alcohol 120% software is recommended for this, as it is known to recover data more efficiently than other ISO software.
If a successful read is obtained, I recommended creating a new CD immediately. Copy all the data from the CD to the hard drive or create an ISO of the CD for immediate use. With a favorite burning utility, burn the ISO or data onto a new CD.
2answers
My dvd rom wont read data but can read video
possibly the lens is weak/dead. repalce.
I am not able to read the data from cd
First of all make sure that the disk is working by checking another cd that was working last time you used it..
then
Make sure that the CD is readable.. There should not be a much of scratch on the disk...
1helpful
When I put DVd in sounds like its loading then I get disc error playback not on this disk
Several possible causes
1. Laser read lens dirty - clean it
2. CD has become damaged & data cannot be read (does it read in other cd drives?)
3. Intermittent malfunction of laser read circuitry.
4. Process of elimination - if CD is readable on other drives, the problem is with DVD player. If cleaning does not solve the problem, the problem is DVD internal electronics.
Scratched cds
anything can be repaired . with enough money and time anyways..
I don't understand why the discs would be getting scratched though.... the only thing that touches the readable surface is a laser.
Maybe the unit is just dirty. Call a local repair shop and ask how much to clean it up... I had a CD jukebox with a 600 disc changer cleaned for under $100 not long ago.
3helpful
2answers
Game Cube will not read disks. Please help!
you can clean the disks using tap water and then drying with soft cloth have you tried a lense cleaner to clean the laser on the cube get a good brand one not a cheap one also you can buy a disk cleaner that gently takes the scratches out of cds and gets them as new but you will have to shop around to get one but these work on anything cd dvd games the lot so deff worth having one as lots of people throw out dvds cd and games due to the scratches stopping them working but remember the data on a disk isnt on the plastic it is on the layey the other side of plastic the plastic is their to protect the data getting damaged so removing the scratches does not damage the disk if you have scratches this will affect the disk because the laser cant read through the scratch so polishing these scratches out will make the disk as new not many people know you can do this so consider yourself having privalaged info hope this is some help to you but you might have to ask arround for a disk repair so good luck you could even charge people to repair their disks and games this works for anything on a cd style disk.........................................................
1helpful
Cd dvd wont play
Many of the older DVD and CD players will not play disks recorded on a computer. This has to do mainly with the laser optical response.
There were several manufactures that manufactured their laser unit with a built in filter that would not allow their player to read non pressed CD disks (disks burned with a home computer).
When buring DVD's or CD's, use the slowest possible speed for the burn to have the highest readablity and least data errors possible for the medium.
Jerry G.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
