Question about Frigidaire 24 in. PLD2560LCC Energy Star® Built-in Dishwasher
PLD2560LCC1 Frigidaire Dishwasher...Control Panel shows 65 minutes left on lower rack, works for about 1 minute, shuts down. None of the buttons work. I changed the control (major circuit) board, same problem. I wonder if it's the control "panel"? I took that off and looked at it. Seems okay, but could the problem. I've heard this model has control problems, but I'm not sure if they mean the major control board or the control panel that has the buttons.
2 Suggested Answers
SOURCE: pld2560lcc1 Dishwasher...Control Panel shows 65
pulled the touch pad, go after the middle third with a very small screw driver, cleaned the flex circut with contact cleaner
powered up fine seems to be working again
Posted on Jan 25, 2010
The dishwasher continue beeping one sound every few minutes, even after I shut down the power. Why and how I can fix it
Good Afternoon Tie, thank you for your inquiry!
From what you have described your Frigidaire dishwasher continues beeping a sound every few minutes even when the power has been shut off. It sounds like this could be a possible issue with your control panel or keypad. I would recommend performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. I hope this information is helpful for you. -Matt
Aug 06, 2015 | Frigidaire FGBD2431KF Dishwashers : Built...
Electrolux PLD2560LCC1 lights flashing
Good Morning Friend,
I understand that you have flashing lights on your Frigidaire dishwasher, model# PLD2560LCC1, and will not start the cycle. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try running the cycle again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 27, 2014 | Frigidaire Dishwashers
We recently had a power outage, the next time I went to run the dish washer it would only run the lower rack 65 min. cycle. I press cancel nothing happens unless I open the door. I have tried selecting...
Hello Stacey, thank you for your post!
I understand the unit recently experienced a power outage. First, let's try reprogramming the dishwasher. This can be done by either unplugging it or flipping the household circuit breaker to the off position. It is necessary to wait roughly ten minutes and then turn the appliance on. If resetting the power does not correct the issue, your unit could be experiencing a communication error with the control board, or a potential wiring failure. I recommend reaching out to an appliance expert who is best equipped to pinpoint the exact problem, which can often save you funds and a headache.
Sep 10, 2013 | Frigidaire Professional Series 24 in....
Frigidaire dishwasher model fghd2433kf1 keeps restarting after a few minutes
rlindaur179,There are a couple possible issues. We will start with the easy ones first.
1. There is a round shape float on the inside floor of the dishwasher.On this mode I believe it is in the front left. please check to see this float moves easily up and down. If there is any build up it could getting stuck in the upright position this can cause a reset in the cycle. Clean the float shaft. Lift float and clean shaft (steel wool works well)2. Replace control board
Hope this helpsJoe Connolly
Nov 09, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
Pld2560lcc1 Dishwasher...Control Panel shows 65 minutes left on lower rack, works for about 1 minute, shuts down. None of the buttons work. I changed the control (major circuit) board, same problem. I...
Jan 23, 2010 | Frigidaire 24 in. PLD2560LCC Energy...
2H displayed and pump runs nothing else happens
I would check the buttons on the control they may stuck. check the delay button..
Dec 21, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Frigidaire professional series dishwasher, PLD2560LCC1
the control on the dishwasher is locked look on the console to see the unlock button it will be in you owners manual this is the problem
May 09, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire 24 in. PLD2560LCC Energy Star® Built-in Dishwasher Logo
305 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
