Question about Mach Speed Trio Portable MP3 Player
When i connect my device to the computer it doesn't register anym
My device xharges when i hook it up but does not register on my computer any more also no longer in "my computer" what do I do?
  • 4 Answers
Your usb plug might have gotton broken and can not register or go to control pannel and check your usb connection manually
Posted on Feb 25, 2009
Magicjack will not dial out when hooked up with phone line modem & wifi??.. phone line filters are installed on all phones, still not working??..
Filters should not be fitted to the phone connected to the magicjack device.
You need a computer to register on line for the first time also connected to the same Wi-Fi as the magicjack.
The magicjack device must have external power on and plugged into the Ethernet connection on your modem/router.
Check you have an internet connection first, via your computer, or it will never work.
Feb 15, 2014 | magicjack.com Computers & Internet
Toshiba x205-59349 hdmi doesn't register on the tv
If you hooked up with set and or a box on that may be the issue--HDMI does not like connections being made with units on.
disconnect power from set and or box if used for a while and then with HDMI reconnected power up the set and or box.
Dec 03, 2012 | Toshiba Televison & Video
Panasonic hdtv 1080i CT-36HX41E..Can you hook up a PC to the tv for the monitor?
You can connect this to your computer if you have an S-Video output on your computer. This is the only supported connection on your TV. This model doesn't have a VGA, DVI, or HDMI port.
Hope that helps!
Jul 19, 2011 | Panasonic CT-32HX40 32" TV
Cannot download pictures. red light flashes when connecting to computer and computer doesn't register the device
For this issue you just need to reinstall the software or driver for your camera. Then restart your Pc. Then you need to connect your camera again to check if the pc will recognized it. You may also try to check if the cable you're using to connect your camera to your pc is not damaged because usually the cable is the one causing the issue.
Hope this help you a bit. Have a great day.
May 18, 2011 | Canon PowerShot S3 IS Digital Camera
Product registration
Hi Noel!
No problem, just go to:
https://my.garmin.com/mygarmin/marketing/register.htm
Choose the device category and you're on your way. If you haven't started a "MyGarmin" account, no worries, you'll be able to do that on the way to register your device.
I was having trouble entering my serial number for my 72H, but I hooked the GPS to the computer and the thing registered itself!
Hope this helps.
Mar 21, 2011 | Garmin GPS
I have a nuvi 1350, how to register for later updates
with the unit Off
connect the gps to computer using the usb cable...( same usb cable most cameras use to hook to computers)
once connected your computer will detect new hardware (usb) minimise box
next
go to www.MyGarmin.com it to will detect your model number and let your register your gps
you will be asked to download WebUpDater utility to transfer files to your gps
Nov 20, 2010 | Garmin nuvi 1350 Car GPS Receiver
Does this come with a usb cable? Not sure how to hook up.
Not sure if it does, some may come with one, its the same USB cable that you hook up your camera with to a computer......
The USB to Mini-USB cable is to download maps and updates for your unit and transfer media to your Garmin
When you get your Garmin you need to register the unit with Garmin so the maps will unlock, this is how you would do it below....
With the Garmin unit off.... connect the mini-usb to gps then connect other USB end to computer
your computer will detect the connection
now go to www.MyGarmin.com the site will also detect what unit you have and let you unlock the map
here is where you register your unit and unlock maps
Oct 30, 2010 | Garmin Nuvi 660 GPS Receiver
Router Won't connect to internet
The cable modem sometimes register the hardware MAC address of the connected device. So your PC may be registered and it won't accept the router now. Connect the WAN port of the router to your cable modem and power the modem off and on again. It should re-register the connected device and now your router should work.
Jul 30, 2009 | Dell TrueMobile 2300 Router (000001)
I deleted files in garmin 205W now I lost voice and languages
I also had this problem while trying to register a Nuvi 205W. I talked to someone at Garmin tech support and found that I was using USB cable that was only meant to plug in to my computer to recharge the unit. I have now sent for a data transmission USB cable, will see if that solves the problem when it arrives. Hope this helps.
Mar 17, 2009 | Garmin nuvi 205W GPS Receiver
Computer wont register camera
Check with JVC and your manual to ensure that this camera can be used as a still camera when connected to the PC. I think even some high end cameras do not have this functionality.
You don't say which version of Windows you are running.
I would check with JVC's web site or on your driver disc to see that there are WDM / TWAIN drivers to allow your GZ-MG130 to be seen as an imaging device in Windows.
Mike
Feb 27, 2008 | JVC Everio GZ-MG130 Camcorder
Mach Speed Trio Portable MP3 Player Logo
175 people viewed this question
Top Mach Speed Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
