Question about Whirlpool TGDX640P Dryer
Estate gas dryer model#TGDX640JQ2 running no heat
Dryer runs but no heat also the auto sense high heat cycle does not time out..all other cycles time out but there is still no heat..where do i begin to fix the problem dryer runs but no heat also the auto sense high heat cycle does not time out..all other cycles time out but there is still no heat..
  • 40 Answers
Well first thing... gas dryers don't have heater elements..
First thing to do is look on the bottom left of the front panel of you gas dryer. there is a small plastic plug to remove to look at the burner. Remove that and start the dryer on a heat cycle, if you look through the hole you should see the igniter start to glow within 30 sec. If not remove the back panel from the dryer and you will see a thermal cut-off (small thermostat with 2 wires) on the burner vent. you will need to remove the wires and test for continuity on the thermal cut-off. replace if there is no continuity. If that tests correctly and or if the Igniter did glow, you will need to open the dryer from the front. Remove the to screws from where the lint screen is and pry the top open . Disconnect the door switch and remove the 2 screws holding the front panel,tilt the front panel forward ,lift and remove. disconnect belt and remove drum.
If the Igniter glows and stays glowing for more the 15 to 20 seconds, replace the sensor on the side of the burner. If it glows and go's out after 20 seconds or so and will not light replace the gas coils. if the igniter did glow at all you may have to do a ohm test on the igniter or take a close look at it, you may see a crack or burn mark on it. Less likely cause's are faulty timer or motor switch.
good luck
Posted on Mar 27, 2015
  • 150 Answers
You may have a bad heating element,unplug the dryer. you need a 1/4 in socket driver to take off the back panel this will give you access to the guts.If your handy you can buy a new one and replace it.Tell me if you need more help.
Hope this helped.Let me know by rating me.
For more help go to live chat.
lenwest
Posted on Jan 30, 2009
Dryer will run but it will not heat?
Heating cycle failure...
a) Heating element faulty.
b) One of the safety switches (Thermal fuse / High temp cut off etc) has burned out.
c) Rare case... Control board not giving power to heating circuit. Control board failure.
d) Heating sensor issues. Try the time dry to see there is heat instead of auto cycle. May be your heat sensing thermistors....
But mostly either above a) or b) reason.
Apr 24, 2015 | LG DLG9588 Dryer
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
Estate TGDS680EQ3 gas dryer blows cold
The timer is stripped inside and needs to be replaced. The cogged teeth are made of plastic and a tooth or two has broken off keeping the timer from moving while running
Jul 16, 2010 | Estate TGDS680EQ Dryer
Dryer lost heat according to different cycles
the model number you have is for a gas dryer if this is an electric dryer then you can access the heating element by removing the back cover this has a small element you can remove it by taking the 1/4 inch screws from the sides of the element there could be two screws or just one remove the screws and pull the element out you con then visually inspect it but the best way is to ohm it out with a meter but your problem sounds more like a timer
Sep 18, 2009 | Estate TEDX640JQ Electric Dryer
Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Apr 02, 2009 | Whirlpool LGV4634JQ Gas Dryer
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 26, 2008 | Whirlpool LGV4634JQ Gas Dryer
Dryer runs but wont auto shut off
On auto dry cycles, the cycle is controlled by moisture sensing bars located on either the rear or front bulkhead, ( visible inside dryer ) if the moisture sensor bars are shorted together (normally by wet clothing) the dryer will continue to run. If the dryer continues to run when the clothes are plenty dry, check and see if there is anything stuck between the sensor bars, (sometimes a metal sequin will cause this) or see if they are damaged. If not, you may have a problem with a timer contact, if the timer advances and stops moving at the same spot each time, I would suspect the timer. If this is an EvenHeat dryer, examine the control board located to the right of the timer in the control panel, for any burned components. Hope this helps.
Sep 15, 2008 | Kenmore 73952 Gas Dryer
Whirlpool TGDX640P Dryer Logo
399 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
