Question about Canon EOS Rebel T2 with 28-90 lens 35mm Film Camera
The shutter inside fell out.
The magnifier that flips inside, inbetween two metals frames fell off and out. Also when you take the lends off it looks as if, on the bottom of the top plastic peice has a chip. i don't recall droping it though.
  • Anonymous Feb 28, 2009
    I have two bodies of the Canon EOS Rebel T2 that have the problem of shutter falling apart. Neither were dropped. Getting them fixed is more expensive than buying a new film camera
    Scholar:
  • 170 Answers
You must be referring to the mirror. In the second part, you must be referring to the focusing screen. If you have not dropped it, there is no likelihood of this getting damaged. You could probably be looking at the split image screen. There is no quick solution for the problem. Please take the camera to the nearest service center.
Posted on Feb 05, 2009
While assembling the seat we loosened the bolt to adjust the seat angle and the pipe fell into the bike frame.
Turn your bike upside down, it should fall out. If that doesn't work turn it upside down and tap on the frame that should make it come right out.
Apr 18, 2015 | Micargi RD 269 Fixed Gear Single Speed...
How to turn off shutter sound
You can't. The sound is caused by a lot of moving parts within the T5i. The mirror reflex flips up, the leading edge of the shutter curtain moves across the frame, the trailing edge moves across the frame, then the mirror flips down. All this happens very quickly, and the sound can be dampened only so much.
Sep 02, 2014 | Canon EOS Rebel T5i 18-135mm Kit...
Camera not working
Hi Jane,
When we press the shutter release the mirror flips up after the shutter opens and closes the mirror flips down. When it flips down we then see out the viewfinder.
At first blush is sounds as though the mirror flipped up but not back down. Remove the lens look inside the camera press the shutter release what happens?
Cordially,
Jul 25, 2013 | Canon EOS Rebel 2000 35mm SLR Camera
I have a Nikon d50, had it since 2006, I took a picture, heard a weird noise, and now the viewfinder is dark as if I have a lens cap on (I don't!) I took off the lens and saw inside the body of the...
Inside the camera is a mirror which reflects the scene up to the viewfinder. It flips out of the way when you press the shutter button. When the mirror flips up, the shutter opens and exposes the sensor. When you look inside, if the mirror is stuck in an up position, you will not see anything in the viewfinder. However, the mirror is super delicate....do not touch its surface or try to force it.
Sep 10, 2011 | Nikon D50 Digital Camera
Spring came off and cannot get the top up to replace it. Series 80 washing machine top load
remove the two screws that hold down the top console,flip up the console,it's on hindges,with a screw driver pop the two metal clips,stick the screw driver in the hole and push back and the clip will release,also there's a white plastic wire harness in between the clips,that's the lid switch connection,unplug it.open the lid,grab the frame and pull back and up and remove the outside frame.if the spring fell off the back of the washer and the tub is bouncing all around,most likely the hole in the frame rotted and you'll need to drill a new hole,hope this helps,let me know how you make out
Aug 25, 2010 | Kenmore 24032\24036 Top Load Washer
Fuel filter location 1999 dodge durango
the fuel filter is located on the iner driver or pasenger side frame railing inbetween the front and rear doors. yes it has filter in the tank which is more comely know as the sock or straner. the filter will look like a metal canister .
Jul 29, 2009 | 1999 Dodge Durango
Microwave shorted out when metal grease filter contacted inside
It might be that the internal power fuse of the MW may have blown. You may have to just replace that fuse if possible. Other wise the electronics (most likely a circuit board) may have been blown.
Jun 29, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
How the hell does the skirt go on this piece of ****?
Put the metal frame on the board - then turn them upside down. The skirt has four slits - where the knobs on the bottom of the board come through - pull the material tautly while snapping on buttons.
Mar 17, 2009 | Kolcraft Light Vibes 18270 Crib
My Bass Drum trigger just stopped working .
this is an easy problem to fix. The piezo piece on the inside of your bass drum trigger uses a double sided tape that is fixed to a metal disc. the piezo trigger just fell off. mine did the same thing. I actually glued mine with epoxy and have not looked back.
Nov 19, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Focusing screen fell out
There is like a metal cradle inside the camera in the roof that flips down. The Focusing screen is to be placed in the roof of the camera with the small tab facing OUT of the camera. The Cradle then lifts upwards and clicks in.
do not touch the main part of the focusing screen. Try only to touch the tab
Focusing screens get damaged easy
Feb 05, 2007 | Canon EOS-1Ds Mark II Digital Camera
Canon EOS Rebel T2 with 28-90 lens 35mm Film Camera Logo
114 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
