Question about Kenmore 94702 Front Load Stacked Washer / Dryer
Spin cycle won't stop
The spin cycle just keeps going and the nob on the front won't turn to the next cycle...The final spin was running for longer than it's suppose to and I had to manually turn the nob to get to the next cycle.
What to do?
  • 15,935 Answers
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Won't final spin ?
What is the model number of your unit?
Nov 04, 2012 | Washing Machines
Water won't stop filling the washer
water fill valve is probably stuck open. see if you can find a blockage or just replace it
Feb 03, 2012 | Kenmore HE2 Washing Machines
Will not go into high speed final spin after rince cycle..only spins back and forth slowly and the uE indicator comes on stopping the machine. Have tried taking out a few laundry items and re-starting and...
uE is unbalanced error. When you have bulky items, wash them with a slow spin speed. Larger loads actually balance out better, so adding items might help instead of subtracting them. After the cycle completes, if you want to you can turn the power on again and (without selecting a cycle) just push the spin speed selector button and select the next highest spin speed. The load will most likely make it through the next higher speed now that it is partially spun out. You should get a 14 minute spin and pump only when you start it now.
Nov 15, 2009 | LG WM0642H Front Load
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
EuroTech EWC177 washer/dryer combo reset
tinaheinleHello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, ..well this is a solution.....
my roommate unplugged the machine while it was drying. the start and spin lights were both flashing. I called the company and they told me to reset it, but the weren't sure how, lol.
I unplugged it and waiting, nothing. I flipped the breaker, nothing. I finally turned it to a setting, and turned on nob on the dry, and it started clicking.
I turned off the dry, and hit the start button, and it started right up...
If the next time you use it and it's fine then you did succeed in resetting the system and will be alright!
Let me know that we were successful!
Please remember to leave a rating before you go!
Thank you
Aug 30, 2008 | EuroTech EWC177 Front Load Washer / Dryer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
No final spin
I haven't experienced that problem, but is it possible that the machine becomes unbalanced with the spinning load and then aborts the spin, so it doesn't finish? Has the machine been properly leveled during installation?
Apr 09, 2008 | Malber WD1000 Front Load Washer/Dryer
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Kenmore 94702 Front Load Stacked Washer / Dryer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
