Question about Maytag PAV2300 Top Load Washer
Post Spin cycle drum winds down slowly- Doesn't stop w/LID opened
The drum does not stop abruptly when the lid is opened during the Spin cycle like it always has in the past.   The power to spin the drum is stopped, but it just winds down slowly.  Additionally, when the spin cycle is over the drum does not stop spinning quickly but rather coasts to a stop.  (around 18 seconds unloaded)
Once stopped the drum can be spun by hand.  If you start a new cycle, the drum is still movable when the water is loading.  Once the water stops and the agitation starts the drum is locked down and can not be moved by hand.  The agitator is working as expected.
The only other symptom is an occasional very short and high pitched "chirp" during the agitation cycle.  Thank you in advance!
  • 20 Answers
You have a bad pully cam or brake
Posted on Feb 10, 2009
Does not spin clothes dry
Run the washer empty on the lowest water level. Cold will save energy. Watch it fill, close the lid, stay there. Don't advance the timer no matter how tempting as this could skip a program interval. When you hear the water draining listen for a sound change and open the top and see if it drained completely -- pumped out empty. Close the lid so the cycle can continue. During the spin cycle open the lid. See if the drum was really turning fast -- it will be slowing down as soon as you open the lid because that stops the motor. If everything seems normal, then the problem may be transmission or belt slipping under load. Do you have the problem only on large loads? If the spin speed is slow during the test then the transmission is not shifting in to high, controlled by a solenoid. Check the solenoid for power during the spin cycle. Operate the washer on blocks or outside on saw horses to see full function of underneath parts and have access to electrical wires for testing. Use precautions testing and plug into a GFCI. Take your car battery jumper cables and clamp to a water pipe ground and to the underneath frame where the motor mounts. This should keep you from getting electricuted standing in water and holding a test meter.
Dec 12, 2009 | Washing Machines
Washer won't spin. Belt is slipping. Tub is stuck.
The belt sounds worn out since its slipping. Change it out. Its cheap fix.
The drum brake does just what is sounds like. brakes the drum. For instance when u open the lid during a cycle and everything stops thats the drum engaging and stops the movement of teh drum. If the brake is malfunctioning two things will happen, you open the lid (assuming the safety switch is still good) or the drum will not spin at all.
Aug 24, 2009 | Maytag LAT3600A Top Load Washer
My washer stops working during a wash cycle leaving the drum full of water and sits there until it decides to start again. I just changed the timer and it didn't fix a thing.
sound like the lid switch put timer to spin cyc open lid pull the timer knob out and the opening that will get depressed by the lid actuator push it with a pen/pencil if works replace the lid switch
Aug 19, 2009 | Whirlpool Washing Machines
Kenmore 110 washer drum spins with lid open during Rinse/Spin
Slow agitator could be linked to shaft bearings going south. Pull the agitator off and check the block on top of the shaft. With everything turned off, try to turn the shaft. It should turn freely both ways. Other things to slow down the works could be a very worn drive belt from the motor.
The lid switch problem seems to be a wiring short--trace the wiring back from the switch to where ever it ends up (at the timer?). If it winds up at a relay, the contacts may be stuck together. It would be nice to have a wiring diagram--ah well. Don't know if any of this helps, good luck.
Jul 16, 2009 | Kenmore 22422 Top Load Washer
Washer stopping abruptly at end of spin cycle.
Hi, it sounds like maybe some dust has gotten in the basket drive pads causing it to stick. Has it been happening long? Sometimes it will work its way out. Try turning the tub with your hand clockwise. You can also put a heavy load in the washer (wet) and let it get to a high spin. Then open the lid and see if it starts stopping slower.
If this doesn't clear its self up, you will need to change the basketdrive.
Please let me know if this has helpped.
Thanks
Vic
May 17, 2009 | Kenmore 15864/15862 Top Load Washer
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Mar 10, 2009 | Kenmore Washing Machines
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Washer Stuck in Cycle
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
Jan 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Washer will not stop spinnig
You probably have a blocked pump. Pull it out and clear the obstructions- buttons, lint, etc
Jun 02, 2006 | GE WJSR2070B Top Load Washer
Maytag PAV2300 Top Load Washer Logo
279 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
