Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ge Spectra Hi My oven suddenly quit heating. Ican cook on top and broil on hi or lo but the oven temp will not rise past the 100 degree mark Can you tell me wht it might be thanks Sara
  • lev505 Jul 11, 2008
    I am having this same problem. I turned on the self cleaning and today the oven will not go on . It stays at 100 degrees. The broiler works. It is gas.
    Can you that unit anywhere?
    Thanks
    Linda
  • jmc67 Jul 12, 2008
    Same here. Broiler and burners all work but not the oven. I removed the oven floor and checked the glowbar - it lights up bright orange, just as intensely as the broiler glowbar, so I'm thinking that it's not the problem. Any suggestions?
    Novelist:
  • 159 Answers
Remove the bottom of the oven you will see 2 screws in the back. once you do that there is a flame baffel on top of the burner held on my one screw. remove that. now turn the oven on and watch to see if the glow bar comes on. I would say it wont or if it dose it is to weak to open the gas valve. Replace the glow bar and you will be back in business. the glow bar is a ware item everytime theoven is on and is heating the glow bar is on . good luck
Posted on Jul 26, 2007
SOURCE:
Oven temp heats higher than set
The control board is bad. One of the relays has fused and you will need to replace the control board.
Jan 07, 2012 | General Ovens
My GE XL44 Self-Cleaning Gas oven heats up but is about 125-130 degrees cooler than what it is set for.
To Adjust the Thermostat
  1. Touch the BROIL HI/LO and BAKE pads at the same time for 3 seconds until the display shows SF.
  2. Touch the BAKE pad. A two digit number shows in the display.
  3. Touch BAKE again to alternate between increasing and decreasing the oven temperature.
  4. The oven temperature can be adjusted up to (+) 35°F (19°C) hotter or (-) 35°F (19°C) cooler. Touch the number pads the same way you read them. For example, to change the oven temperature 15°F (8°C), touch 1 and 5.
  5. When you have made the adjustment, touch the START pad to go back to the time of day display. Use your oven as you would normally.
Feb 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
The heating element becomes red hot,but the food doesn't appear to cook in an appropriate time os fashion. Any answers or suggestions
The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
Nov 04, 2010 | Hotpoint SY36 Style Line Stainless Steel...
The temp for bake says 200c what do I set it on for 375 degrees?
265c63b.jpegPress BAKE and BROIL hi/lo
pads for 2 secs till display
show "SF".
Press BROIL hi/lo pad. The
display will show "F", if yall
want "fahrenheit" then hit
START. Press Boil hi/lo again
and yall will see a "C", if
yall want "centegrade" then hit
START. Most stoves.
If you ha listed a make and model it woulda been much easier.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 21, 2010 | Ovens
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
No broil or oven cook top works
try checking the ignitor or the thermostat in the oven.
Sep 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven does not heat over 100 degrees
Hi
It sounds you need a new control panel circuit board.
hope you will be helpfull
Thanks for contacting Fixya.com
Sep 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a Kenmore oven with no directions. We cannot get the broiler to work. Can you tell us how to do turn it on? billiejack69@hotmail.com
Here's the manual for your oven, based on the model number you provided.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0522659.pdf
If this isn't your oven, use the following link to enter in your model number to get the correct manual, free.
http://www.managemyhome.com/mmh/ (click on the manual tab)
Hope you find this Very Helpful and best regards!
Here's how to use the broil function of your wall oven:
Press the BROIL pad. (This will
automatically set HI Broil).
lb. While the set indicator is flashing
in the display, press the BROIL
pad again if you prefer to use
Lo Broil. Use Lo Broil to cook
foods such as poultry or thick
cuts of meat thoroughly without
over-browning them.
2. Press the START pad.
3. When broiling is finished, press
the CLEAR/OFF pad.
Aug 28, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven won't broil
You probably have a bad broil ignitor. When you turn the oven onb to broil the ignitor on the top of the oven should glow bright orange. If it doesn't glow or glows a dull orange, it is probably bad.
Apr 08, 2009 | GE 30 in. Gas Self Clean Slide-In Range...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
320 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
