Question about Kenmore Elite 45986 Front Load Washer
My he3 washing machine does not spin all the water out
Sometimes there is a lot of water in the tube when you go to put in the next load
  • Anonymous Jan 31, 2009
    my washer wont spin. it tries, but then stops
  • 29 Answers
DOES IT SPIN UP TO FULL SPEED? IF SO YOU HAVE A WEAK PUMP OR A CLOG IN THE HOUSEHOLD DRAIN PIPE.
Posted on Jan 29, 2009
Kenmore He3 sometimes sound like a jackhammer in spin cycle
Have you tried less items? It could be the load is not balanced. Try placing items around the tub evenly. This unit is about 12 yrs old so it could be a bearing.
May 03, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
The washer will not stop filling up with water and spilling water on the floor unless manually stoped. Sometimes it spins and rings the clothes out and sometimes it doesn't . With either problem it...
Remove front of machine with putty knife/slide knife in at top of front on left and right u will see the tabs.. there is a pressure tube that attachs to tub on the left side remove tube. DONT BREAK OF THE *** it is most likly pluged use small wire to clean tube and the little *** that it gos on to// put tube back on (SPIN AND DRAIN MACHINE) test on all load sizes.. good luck thank you for voting.............................
May 21, 2011 | GE Washing Machines
Sometimes the water will not drain out, of my Kenmore Elite HE3 washer and it will display 02F. The door will not open, when I press the drain/spin button it makes a funny noise, won't drain, nor will it...
Hi, You pump filter screen is clogged up of you may even actually have something stuck in the pump. Unplug machine, remove the bottom front panel 2-3 screws along the bottom. look for the filter/screen housing next to the pump. place a shallow pan under it. Be prepared for lots if water and debris. Unscrew it slowly to drain then screw it back in to shut off and dump pan repeat until no longer full of water. Remove and clean all debris out screen, housing and hose.
Nov 01, 2010 | Washing Machines
Front loader Kenmore HE3 drains but after several hours water accumulates in the machine. I can then spin it out but it will reaccumulate.
Thye problem is the water inlet valve is hanging up. The valve will need to be replaced. They sometimes get debris inside and stop seating. They are usually inexpensive and easy to replace. Here is a link that should help Water inlet valve replacement
Oct 02, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore elite he3.on spin cycle makes lots of noise like a motor mount broke.
It could be that you are not setting the water level high enough when you do large loads.also the strap that holds the cement block could have come undone and now the block is unsecure.
Jul 18, 2009 | Kenmore Elite 45986 Front Load Washer
Washer won't spin- flashing "f 02"
in the HE3 series it means the drain tube or pump is clogged
Mar 02, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore he3
The Belt in the back has come off. I am dealing with the same issue now.
Jul 12, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Ran HE3 without Water, it's now locked up
Unplug the washer and wait 30 minutes, sometimes the next morning for the machine to reset. Make sure the water is on because it while find multiple failures and lock up, Secondly you can try putting the machine into diagnostic cycle to ensure it is ok. Press drain/spin and select no spin for spin speed finally press prewash quickly two or three times and let it run, any flashing codes?, hit prewash again after writing the codes down.
Jun 15, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Drain & Spin issue
Have you checked your water pump? Sometimes this is an issue of the strainer being plugged as well. Do you get any flashing error messages on teh screen?
Jan 14, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
102 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
