Question about GE Refrigerators
Evaporator freezing up on my ge gss25tsrd refridgerator
Ge refridgerator is not cooling the evaporator core is freezing up
  • Anonymous Mar 25, 2014
    admiral refridgerator model HM19145
  • 29 Answers
YOU CAN SEE HEAVY FROST ON THE REAR OF FREEZER WALL?
Posted on Jan 29, 2009
Assuming that the circulation fan is running and none of the ducts are blocked the problem is likely to be caused by frost accumulating on the evap core over time and it will eventually cause it to ice up. normally the frost is melted away during the defrost cycle (this it what makes a freezer (frost free") Ge redesigned the defrost heater with a 2 element heater to rectify the problem. The new part cost is about $35.00 and should completely dry out the evap core during the defrost cycle and solve your problem.
Posted on Aug 17, 2010
GE gs22jepacc side by side refridgerator
Typically a frost build up would indicate a low charge. Partial freezing as evaporation happens too quickly in part of the circuit. Check the charge.
Nov 16, 2013 | GE Refrigerators
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
My air conditioner will cool for about 5 minutes then starts blowing warm air. i have replaced orphus tube and all filters. when it starts blowing warm air i get a wet dirt smell in the cab. is it my...
I think you are right. The core may be restricted or leaking refridgerant. The moisture could be condensation on the evaporator that is building up inside because of a plugged or broken drain hose. (the water you see on the ground under a car when the A/C is running might be dripping inside the cabin)
Mar 17, 2011 | 1999 Chevrolet Silverado 1500
I have a GSS25TSRD SS refridgerator. The 4 year old appliance recently is giving two problems. Water seems to be leaking in the freezer department from the back of the Ice maker, and freezes the vegetables...
Ok, I would love to help,
Please respond to this using COMMENT or REPLY
I believe this is fixable
Do you know if the party using the fridge has damaged it accidently in any way?
Jan 13, 2011 | GE Refrigerators
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
Refrigerator side not cooling
The fresh food section is cooled by the freezer section by forced air supplied by a fan. If you have air flow, check the temp inside the freezer. It should be between 0 and -10. If not look inside your freezer and see if you have ice built up on the back panel. If so you have a defrost problem that is most likely a bad defrost heater, a bad termination thermostat or timer. If ther is no ice then check your fan under the refrig. If you can hear the compressor running it should be turning. If this all checks out then you have a freon system problem like. Low Freon pressure or a restriction.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Artica Side by Side Refridgerator isn't cooling.
You say fan seems to be working? it either is or it is not working. If you are getting a reduced airflow in the cabinet, it may indicate that the evaporator coil is iced up and needs to be manually defrosted.
May 08, 2009 | Refrigerators
Refridgerator not cooling
is it side by side or freezer on top/bottom...check to see if the fan inside the freezer is running when the compressor is running..also check to see if ice is covering the evaporator coils.. the freezing should be even with a thin layer of ice/ not partically melted..sometimes the ice forms in the vents and stops the air flow...to review...check and see if fan is working in freezer
check to see if vents are clogged......good luck!!
Apr 29, 2009 | Refrigerators
Freezer not working - GSS20IGPA WW
All cooling starts in the freezer section where the evaporator is. Too much stuff in the freezer can inhibit the necessary airflow around the evaporator and cause it to freeze. Usually, the next defrost cycle will thaw it, but it can keep the cool from coming out. There are so many things that can cause the lack of cooling, but most often, it is NOT the compressor. e.g. - if there's water pooling on the inside at the bottom, you have a bad door seal. If no real cool ever happens and you don't hear the hum of the compressor often, you defrost timer is bad.
Jun 09, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
399 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
