Question about Linksys 2.4 GHz 802.11b Wireless - B PCI Adapter (WMP11) (LINKSYSWMP11)
Linksys wireless g 2.4ghz, 802.11g broadband router
We have this equipment at home and we can't find how many volts is power supply. 9.5v, 12v or what?
It will be very helpful that manufacturer will label electric data at power input and in larger letter size. Where is sence amd logic that sometime main informations are missing or written tiny, almost not readeble letters.
Also we ahve instant wireless network pc card and we cant find how its working and whwre to place.
In our box that we bought at show we do not have manual and poweraddapter. To whome contact ?
What is the best way to connect 2 computers on cable Time-Warner?
    New Friend:
How many volts should use for my linksys wireless-g 2.4 ghz
802.11g
Posted on Dec 19, 2013
  • 689 Answers
Most Linksys routers works between 5V to 12V, If older versions 5V is safest. However if you provide exact model of the device we can provide information accordingly
Posted on Jul 08, 2009
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
I need power supply for Broadband
This router uses a 5 volt 2.5 amp power adapter.
You can download the manual from this WEB site and the specifications for this unit is on the last page.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000000300.pdf
Jun 12, 2012 | Linksys Wireless-G WRT54G Router
I need a simple set-up manual for model # WRT54GS router
Your Internet service provider is comcast cable company.
You need to open the setup page of the router and change the Internet connection settings manually.
Connect the computer to the router and modem to the router.
Open the setup page of the router using 192.168.1.1
Click on MAC address clone. Enable it and click save settings.
Power cycle the router and your main computer will be online.
Then you can change the wireless settings manually.
Click Linksys router setup steps
Jan 04, 2012 | Linksys Wireless-G Broadband Router
Need a power supply for a linksys WRT546 What are the voltage requirements for this model?
The Linksys WRT54G requires a DC power supply of 12V.
You can purchase this power supply from any electronics store or online vendor.
Mar 07, 2011 | Linksys Wireless-G WRT54G Router
Do I need any special equipment other than the ethernet cable connection for my linksys broadband wireless-g router
That's all you need to get your wireless internet up and running. However, in order to connect computers to the wireless network, they must be wireless capable, for example, most laptops have built in wifi, however desktops will need a wireless adapter to take advantage of your wireless router.
Mar 03, 2011 | Linksys Wireless-G Broadband Router
I have Linksys - WRT54GS Wireless G Broadband Router working fine for the last 3 years and since one hour stopped working. I cannot see the light blinking on on wireless icon on the router. Any suggestions...
I've gone through two of those routers in a similar amount of time, it has most likely bit the dust. You can try connecting to it via wired and typing in the address (the default is 192.168.1.1) into Internet Explorer. There you will find the web configuration site for the router. Once you've logged in (the default access password is admin with no user name), go to the wireless tab and ensure that the wireless is not disabled (it will say, G-only, Mixed Mode, or disabled). If it is disabled, change it to the mode you need and apply the settings before you log off.
Jan 26, 2010 | Linksys Wireless-G Broadband Router
My linsys wireless g broadband router appears to
Check your power adapter with a digital multimeter. Make sure the voltage is no higher than .5 volts than what's listed. If the voltage is malfunctioning and it gets to high, it can damage the ethernet port and more on your system if it is connected wired.
Aug 09, 2009 | Linksys Wireless-G Broadband Router
Laptop cannot connect to router
also make sure that the firmware is updated for the router. go to the linksys site, find your model and download latest firmware.
Jul 13, 2008 | Linksys Wireless-G Broadband Router
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
363 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
