Question about Baby Gear
Jmason open aire swing
My jmason open aire swing stopped working. changed batteries already. still doesn't work. what else can i do? do you have a customer support ph. # for jmason?
4 Suggested Answers
SOURCE: how do I connect the
If you are using the correct end of the bar (not the end with notches and buttons) it should slide right over the end of the bar and wires.
Posted on Feb 16, 2011
  • 135 Answers
SOURCE: My remote stopped working, I
have remote checked out at advance auto,could be ur keyless entry sensor bad
Posted on Aug 21, 2011
Testimonial: "awesome"
mechanicsonl
  • 431 Answers
SOURCE: remote locking 1999 prado stopped working
try this see if it works ( should do )
you have 15 seconds to perform the following 3 steps:
1. All doors closed. Key not in cylinder
2. Insert already registered master key in the key cylinder
3. Turn ignition switch from the LOCK to ON position 5 times
then
Within 20 seconds, Open and Close the driver's door 6 times
then
Within 10 seconds, remove the master key from the key cylinder.
then
Within 10 seconds, insert the key to be registered into the key cylinder
then
Keep the ignition switch at the ON position for 60 seconds or more
Remove key
Open and Close the driver's door once
End of procedure
other than that take it to the dealer GOOD LUCK
Posted on Dec 10, 2011
My soothing motions glider isnt moving at all ?
The terminals are probably still a little corroded from whatever you had to clean out earlier, with was more than likely battery acid. Get a few q-tips, hydrogen peroxide, a small bowl of water, and a dry rag.
First, brush out any dry stuff you can see. Those keyboard air cleaner things work great.
Get the end of one q-tip wet with the hydrogen peroxide (not dripping wet) and start on the "+" end of the battery slots. Just work on one slot at a time. After you rub the q-tip around , start on the "-" side or the side that has the spring in it. This is a little harder because you need to gently clean between the coils. Use the other end and remove everything the q-tip will remove.
After you've cleaned one slot, use either another clean q-tip or your rag to wipe it down with the water. Lightly dry it off, then move on to the next slot.
After you've done the entire compartment, check the cover plate too and clean it as needed. Leave it all out in the air overnight to dry completely before trying to do anything with it.
It might not work right away if there was a battery leak and it got back into the electronics a little. Don't be sad if it doesn't work right away, let it sit another day (with no batteries in it) and try it.
If it still doesn't work then the problem is deeper down into the glider's electronics, in which case you might try calling the manufacturer. Fisher Price has a pretty nice customer service department if you can wait through the "on hold for the next available" stuff. They have been able to suggest some strange things for me that got my baby's favorite things to work again. Post again if you still need help, I've cleaned a lot of battery compartments!
Sep 12, 2012 | Fisher Price Soothing Motions Glider Baby...
Swing stopped working
Had the exact same issue, so I called FP. I had already taken the motor housing off to see if it was something obvious, like a loose connection or broken part. I didn't see anything wrong so I just cleaned it up and put it back together. When I called they offered to sell me a new motor for around $80. Then the lady I was speaking to (who was typing as we talked) said "hey, wait, there's a note in here about this issue..." She said to do what I had done, lightly clean it out with something like a keyboard cleaner, then using the plug (not batteries) set the speed to two/center. It somehow resets it.
That worked for me, and it was free. If that doesn't work then yes, you can get a motor directly from FP. Call the customer service number listed on the back of your manual, if you have it, or 800-432-5437. You'll need to have it nearby so you can give them the model number and year that is listed on the back of the motor housing (open the battery compartment if it isn't on the outside).
You can also get motors online, especially ebay, from any of the papasan swings FP makes. I love this swing so much that I think it's worth it. I've used it for four years now and plan to use it in the future.
Aug 01, 2012 | Fisher Price Starlight Papasan Cradle...
My Canon SX120 suddenly stopped working after about ten months of regular use. I was uploading abpout 50 photos and ten videos to Picasa as usual and even freshly charged battteris do not work now. It...
Ten months ur camera still under warrenty,call and talk to the Canon customer services.Ten months the camera litum battery should not have ben in trouble already,could be the transformer or the power A/C cord adaptor itself it is not functions properly for the battery to be charging or it could be damages to the A/c power cord itself than it is not taking in the A/C power juices to charges the litium battery.Litium Ion battery last at least a 1 1/2 or 2 years by of 8 hrs of charging and able to used the equipments for the battery juices like 2 1/2 to 3 hrs of battery power to be used.
Oct 28, 2011 | Canon PowerShot SX120 IS Digital Camera
Cabal online ph doesn't work on my windows 7 why?
yup ..cabal doesn't work in window 7 os .only window xp operating system can installed it :) try to change your OS then play cabal
Jul 09, 2011 | Computers & Internet
Air swing has stopped working
Check power to air swing. if it's in window a/c. If power, motor is struck or open.Replace motor.
If it's with DC connection, you have to replace motor if not working. Thanks.
Feb 05, 2011 | Panasonic Heating & Cooling
How do I connect the side of the jmason open air swing. There are little wire things sticking up proventing me from connecting the bars
Feb 04, 2011 | J Mason J5101
Fisher Price Nature's Touch Cradle Swing - Not Swinging
Parts for your model can be found on amazon, here:
Amazon com fisher price swing replacement parts. I hope this helped you. Best of luck
Oct 03, 2008 | Baby Gear
Baby Gear Logo
120 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
