Question about RCA HD61W66 61" Projection HDTV
Convergence Menu how do i get to the convergence menu on a 61'' RCA big screen. i cant seem to find it on any of the menus
  • RCA Master
  • 3,459 Answers
If the converegence circuit has failed it wont show up till you fix the TV.
This is a common problem on this model. Call in a shop or do it yourself with parts and instructions from www.TvRepairKits.com
Posted on May 11, 2010
How do I adjust the convergence on an RCA HD52w59?
How old is the tv? all the new one are done through the remote by entering service mode.
Sep 08, 2014 | RCA Televison & Video
How to do a manual convergence on my big screen
Its done under the on screen menu under picture settings. If its not there you will need a repair kit for that symptom. Kits are available for the missing convergence option from www.tvrepairworld.com which contain the parts and the cd with instructions.
Dec 11, 2009 | RCA HD61W66 61" Projection HDTV
Cant find convergence on menu screen
The HD61LPW42 is a RCA DLP which doesnt have convergence. If the convergence is out of alignment you have a three CRT TV such as the D52W19, HD52W59 RCA Check the model number from the rear tag and let me know what the model number is.
Nov 21, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Rca p56926 screen is concave and cant adjust convergence in menu
Convergence can only be repaired by going into the unit itself....You MUST know how to do this or risk a lot more problems.....seek qualified assistance!
Aug 29, 2009 | RCA P52926 52" Rear Projection Television
RCA HD61W66 My Picture Went Round and The Three Colors Are Out Of Sync. And the menu screen would flash on and of erratically.
Ur convergence is dead.Tries these websites.Tv Repair World.com Shopjimmy.com.For many DLP Tvs convergence kits for repair.
Jun 25, 2009 | RCA HD61W66 61" Projection HDTV
My 61 inch RCA HDTV shows a redish shadow outlining each object
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
47a7bc4.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 11, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Trouble with rca rear projection tv
  • Screen looks 3D
69189a5.pngCONVERGENCE SOLUTION
Feb 16, 2009 | RCA P61950 61" Rear Projection Television
3d image
This is what known as a convergence problem. First question is in your setup menu do you have a convergence option.. if you do then do you have any control in that mode does the crosshars move up and down and side to side... if you dont then you have a convergence power supply issue.. if you do it could be a setup issue. IF you do not have convergence in your setup menu then it possiblely be a special fuse.. and bad electrical connections. so let me know and ill see if we can narrow it down further
Jun 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture too big for screen
if anyone has this p61960 television that does not work anymore, I am looking for parts for mine and would buy, please let me know, thanks
Oct 14, 2007 | RCA P61960 61" Rear Projection Television
RCA HD61W66 61" Projection HDTV Logo
192 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
