Question about Aspire Acer AS5315-2856 Laptop
Laptop is down.
It won't turn on at all. I've tried taking out the battery and runing it off of the power chord and also power chord with battery in and still doesn't turn on. No light flashing anywhere. I'm worried i've fried my mother board but i'm not sure. It's an Acer Aspire 5002LMi.
Toshiba A205-S5809 Wont power on
Try another cord/charger with the EXACT same power specs. If you have a multimeter, verify DC voltage at the AC jack plug. If the AC jack, in the laptop, has been pulled, damaged, it's may have a loose connection. You didn' say if ANY LED's, battery charge, work? If the battery is charged and it doesn't start on battery only, then you have other issues. It may need a ride to a Qualified Computer Tech.
Jan 08, 2013 | Toshiba Satellite A205-S5809 Notebook
My Acer Aspire 5810tzg won't start, I've check the power cable and battery and they work fine on other machines, it just won't turn on
There is one thing you can attempt before seeking repairs. You should try a power reset.
1) Unplug the AC adapter
2) Remove the battery
3) Hold down the power button for 30 seconds and then release it
4) Insert battery
5) Plug in AC adapter and see if the laptop can power on
If it does not power on, you may need to seek support with Acer.
Oct 24, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
Hi, I've had my Acer aspire laptop for a few years now, but I haven't used it for over a year (Because I got a desktop). So when I've come to turn it on today, It won't work. The screen...
Start with pulling the battery and power, then hold the power button in for about 30-40 seconds. Then plug the power back in (still no battery). Try to power up the computer. If it boots, shut it down and put the battery in and try again. If it boots the issue was cleared. If it boots with the power cord but not with the battery added, you have a battery issue.
Hope this helps
Sep 01, 2011 | Computers & Internet
Power does not on my laptop
This could be one of several reasons. The most common reasons that a laptop won't power up are a dead battery, or a non-functioning charging chord. My first step would be to plug the laptop into an outlet in the wall that I know for a fact works. If I am unfamiliar with that specific plug, I will plug something into that outlet that makes noise or light. Such as a lamp, stereo, or phone charger. After you have verified that the wall is giving electricity to the charging chord, the next step is to check the next step in the power chain. That would be where the chord from the wall plugs into the transformer box, that plugs into the laptop itself. So the first step is to check that the outlet that charges the laptop is receiving power. As a side not just because a top plug is getting power does not mean that a bottom plug is as well in my experience. After power received, next check connections. Those connections will include the transformer connection, and the laptop connection. Also you may wish to check for cut, loose, frayed, taped, kinked, or otherwise dangerous looking chords. I also do not recommend using third party Universal laptop chargers bought from the store. I only would use one of these in an emergency situation. I don't trust the power regulation. And on top of that a laptop charger chord is so much cheaper on-line if you buy from somewhere like e-bay. That charger will be laptop model specific. Generally a new charger is about $15-35 on e-bay, and a new battery could be as cheap as $50. Although I would also recommend finding out if your laptop is under warranty. If it is within a year old this is a good possibility. That route takes a lot of patience, but it is usually free.
Aug 31, 2011 | Computers & Internet
My HP Pavillion laptop g61 wont turn on or off. There is no fan running it doesnt sound like it is on but the power button light is on and wont turn off. The screen just stays black. I have tried charging...
I had trouble looking up that model on the HP page, but you should check this page and see if this model is affected by this NVidia litigation. If it is, you can get it fixed/replaced on NVidia's dime.
http://www.nvidiasettlement.com/affectedmodels.html
Oct 15, 2010 | HEWLETT-PACKARD Pavilion G61631NR Notebook
I HAVE A LAPTOP ACER AND THE POWER DOES NOT TURN ON
It could be a battery problem. Try switching to AC mode by plugging in to an AC outlet using your Acer power chord (battery charger also). If the charger led don't light, it means it's defective and it can't charge your battery. Please try another power chord or battery charger then. Just remember to take out your battery when using your laptop in AC mode to lengthen your battery life. Regards!
Jul 05, 2009 | E-Machines eMachines Desktop PC
My laptop just keeps shutting down
hey! your laptop battery is no longer accurate and ineffective.. i had the same problem before and the only thing the manufacturer offered me to do is purchase a new battery.. i think you should do too...
Jan 30, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Aspire Acer AS5315-2856 Laptop Logo
52 people viewed this question
Top Aspire Computers & Internet Experts
Jax Planet
Jax Planet
Joe Goldman
Joe Goldman
john smith
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
