Question about Hotpoint RGB524 Gas Kitchen Range
Hotpoint RGB524 Oven won't light.
Burners work great. Oven will not light
  • phoage May 10, 2009
    This unit has a pilot light that is lit, not electronic ignitors. When
    the oven is turned on, the pilot flame gets larger and it soundslike
    gas is coming out but will not light even if a match is held tothe
    burner.
  • 29 Answers
CHECK OVEN IGNITOR, IF IT IS GAS.
Posted on Jan 29, 2009
How can I manually light the oven if the igniter does not work?
Is it a natural gas oven? I remember old times, when igniter didn't work, my 91 years old great-grandmother opened the gas and used a match. This procedure is considered rather dangerous but it never exploded to her...
Jul 26, 2015 | Hotpoint RGB524 Gas Kitchen Range
Burners and oven on Hotpoint free standing electric stove won't heat at all.
Find someone with a good electrical meter and have them test the sockets to see if there is any electricity to the burners.
Also, check each burner and check for continuity through the burner itself.
These elements can all burn out, I've see it happen.
Be blesssed.
Apr 17, 2013 | Kitchen Ranges
The pilot light is on but I am not gettintg any smell of gas going to the oven. All four burners are able to light but I cannot get the oven to light.
When the oven lighting mechanism lights the gas the flames heat a temperature sensor that, once hot, increases the pressure in the sensor's copper pipe and opens a safety valve to allow gas to continue to flow (It's made like this so, if your flame gets blown out, the sensor cools and cuts off the gas supply, making it safe from gas leaks). These sensors occasionally fail, and very sensibly "Fail safe" - No pressure in the sensor pipe, the valve won't open and there is no gas to the burner.
If you take a look inside the oven at the back where the burner is, you will see the sensor, usually the bit that is in the flame is cylindrical, about an inch long made of metal about 3 or 4 mm thick, tapering at the end. It will be held in place by a nut that fits on a thread at the base of the sensor. Running from the sensor is a copper pipe that runs to the cutoff valve. Unbolt the sensor and withdraw it from the hole it is mounted in, trace the copper pipe back to the valve (where it is usually screwed into the valve with a 10mm connector that looks like a car brake pipe connector. Unbolt from the valve. These sensors are widely used on most gas appliances (Boilers, gas fires, cooker hob burners and patio heaters all use the same kind of sensor). You should be able to get a replacement from any gas appliance service agent. If you go into a shop, take it with you. The only thing you need to do is make sure the replacement you get is long enough. If you are offered one that is slightly longer, that
Jul 18, 2011 | Hotpoint RGB524 Gas Kitchen Range
My oven was working fine earlier and now just went to light it and nothing happens.... Any ideas?
Hi, Jus because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 17, 2010 | Hotpoint RGB524 Gas Kitchen Range
Where is the Hotpoint RGB524 Gas Kitchen Range pilot light located and how do I get it lit? I turn knobs and hear a spark sound but no flame. Thanks in advance..
The spark should light the pilot automatically. If you open the broiler door and look up at the left rear side of the burner, you should see the pilot assembly and the spark igniter. Try lighting the pilot by hand with a match, right where the spark is. If it lights, the oven should come on. If it doesn't light, there may be a blockage in the pilot assembly, like a spider web or something. If the pilot seems too small, it may set for LP and you are on Natural gas. The adjustment for that is behind the oven knob, a screw. Good luck.
Mar 27, 2010 | Hotpoint RGB524 Gas Kitchen Range
Hotpoint electic stove, the burners and the oven not working
Is there any sign of life? Does the oven light come on or does the clock work? Just for kicks, go and reset the breaker - it should be a double breaker for a 220V appliance - sometimes half will throw and still leave 110v that will run the light / clock.
Jul 26, 2009 | Hotpoint RB757 Electric Kitchen Range
Hotpoint RGB524 pilot won't light
sounds like you have a standing pilot system.if so and you have turned up the adjustment screw and no better .you will have to replace the pilot tube assemblie
Dec 31, 2008 | Hotpoint RGB524 Gas Kitchen Range
Replacing thermostat
thats very easy first unplug the stove lift the top it should stay up with the arms extended,pull the arms out of the slot and remove oven top , gently pull knobs off , remove all hidden screws behind knobs, remove the front panel held in place by 2-3 screws on top and under panel, remove 2 screws holding existing thermostat unplug 2 wire thermost follow capillary to sensing bulb which is inside the oven unless it broke off it should be there, im asuming thats why you are replacing it ,remove sensing bulb from 2 brackets holding it in place make sure its perfectly straight because it has to pass through a small hole, installaton is the opposite of removal good luck.
Dec 28, 2007 | Hotpoint RGB524 Gas Kitchen Range
Hotpoint RGB524 Gas Kitchen Range Logo
789 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
