Question about Zenith B27A11Z 27" TV
The coax cable is boa=ken on the back of my tv how much would that be to fix?
  • 3 Answers
I'm in Canada and it ranges from about $80 to $150. Most are just a simple solder joint. Be careful if you get it fixed not to over torque it. Finger tight on the back of the set.
Instead of fixing it I alot of time recommend using a Digital Cable Box (or satelite tuner) and hooking it up using component. It will be about the same price and you get a little value for you money.
Posted on Jan 29, 2009
Panasonic DMR - HW100ebk.......... with both coax
So you have looped the coaxial through the Panasonic to the TV and have a HDMI from the Panasonic to the TV, right. When you turn on the DMR select the appropriate HDMI connection with the TV remote and you will be OK.
Oct 11, 2013 | Televison & Video
How do i hook up a dvd player to my tv if i have cox cable? I dont know what channel to put my tv on. I know there has to be a way to watch a dvd without unhiiking the cable
Most DVD players have a coax input and output on them. But some newer ones don't. Assuming your does then you can run your DVD player to your TV with a coax cable you bet. Either on the back of the DVD player there will be a little switch or in the menu settings it will give you an option for channel 3 or channel 4. The same channel you select on the DVD player will be the same channel you will want to put your TV on. For the coax install run it from the output on your DVD player to the coax input on your TV. If you use a coax for cable too then just run you coax from the output on your cable box to the input on your DVD player.
Mar 20, 2011 | Samsung Televison & Video
I have this TV that is a 2008 samsung but i cant hook up the cable line because i dont have a cable box i only have the coax cable line comming out of the wall in my liveing room, problem being is that...
If you have an older VCR, you can connect the cable to the vcr "in" , then connect the A/Vcables from the video and audio out of the vcr to the A/V on the set and put the set on av1 for source. If you don't have a vcr then you will have to get a box.
Nov 27, 2010 | Televison & Video
How to fix the antenna anolog cable connector that to coax cable connects to on back of TV.
Cut off the bad connector on the end of the coax cable. Go to Radio Shack, Home Depot, etc. and pick up a new twist-on coax connector, or a crimp on version if you have a crimping tool.
Twist the new coax connector on good and tight and you should be good to go.
Mar 30, 2010 | RCA HD52W59 HDTV Projection Television
The connector at the back of the tv where the cable would be connected broke off during a move. My step dad took the remaining piece out. How can we fix this? Is it a simple thing we can do ourselves?
The coax connector you describe is fairly low-tech, so it can be fixed. You need to open the back of the TV (careful - high voltage in the capacitors) and locate where it came from.
The best thing would be to take some coax cable and solder the appropriate parts (shield and center conductor) to their exposed matches where the break occurred.
You can then run that through the existing hole, put a screw-on F-terminal end on the piece of coax, and a coax coupler on that.
Home Depot, Lowes, Radio Shack, etc. all have these raw parts.
Jun 30, 2009 | JVC AV-27220 TV
Tv with out coax inputs.
you can run it through a cable box or vcr that has a coax input and rca output.
Apr 14, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
Loose cable connection plug
tv back cabinet to second hole to fixing cable hooked
Aug 23, 2008 | RCA F27442 27" TV
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Aug 30, 2007 | Sharp 27J-S100 TV
Zenith B27A11Z 27" TV Logo
26 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
