Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
I HAVE A BOSCH SHU5315UC THE MOTOR IS RUNNING BUT NO WATER IS COMING OUT CAN YOU GIVE ME AN IDEA WHAT TO DO?
  • Anonymous Feb 08, 2009
    I HVE THE SAME PROBLEM
I had this same problem, It seems to be caused by a sticking float. Try filling it with water by hand with a few cups of water and then try running it through the rinse/hold cycle.
Posted on Mar 08, 2009
I have a Bosch SHU5315UC and the only cycle that will run is the rinse/hold. None of the other cycle buttons will work. It seems as if they have no resistance or spring back when pressed. Any ideas?
Depending on age and other factors; key pads do wear out and require replacement. Many of these controllers us a silicone positive touch system like the keypad on a computer. Others use a direct contact system that has a spring action and contact points. If the later fails, it can be due to use, a breakdown of the recoil system, or damaged contacts.
Mar 17, 2014 | Bosch SHU5315UC Dishwasher
Letter F appears on screen, and dishwasher does not start. Sounds like pump runs for a bit then stops. Door is closed. What is wrong?.
Hi
Error code F indicates that dishwasher control has detected a fault with dishwasher filling. This is due to faulty water inlet valve. Please check for clogged water inlet valve. Water inlet valve part#35
You can buy it from this link---
Bosch SHU531 water inlet valve
Hope this helps... Please post back if you need more information
Daniel
Nov 10, 2010 | Bosch SHU5315UC Dishwasher
Dishwasher began leaking underneath when turned on. Humming as if trying to start, but nothing further exept water on floor
I don't know how old this dishwasher is but the symptom your describing sounds like the ceramic water seal on the bottom of the impeller assy but above the motor has failed. When the seal fails it allows water to run though the motor and then the bearings in the motor fail. Once water starts running though a dishwasher motor they are pretty much shot. The reason for this is that the leak starts out slow and it leaks for a long period before you ever see the water under the dishwasher. So by the time you see the leak water has been going through the pump / motor assy for weeks or months. By that time the service technicians only option is to replace the motor pump assy.
Kelly
Apr 14, 2010 | Bosch SHU5315UC Dishwasher
Bosch SHU5315UC dishwasher doesn't end cycle
make sure 120 degree water enters the diswasher
Feb 08, 2010 | Bosch SHU5316UC Dishwasher
My Bosch shu 5315uc does not advance to rinse or dry. Machine just keeps running. Dishes are dirty and smelly. Manuel says to check if water line is closed or inlet filter blocked. Have no idea how to do...
The waste pipe may be blocked or partly blocke. Is this connected with another appliance under the sink?( T junction?. It may be blocked or partly blocked.
Oct 11, 2009 | Bosch SHU5315UC Dishwasher
Dishwasher does not circulate water
I had a similar issue and it was the Motor Circulation Pump. Part #239144 @ Marcone Appliance Parts Center (860) 548-0080
Feb 01, 2009 | Bosch SHU5315UC Dishwasher
Dishwasher not drying - Bosch Integra SHU9952
Bosch generally drys through evaporation from hot water rinse. There is a common circuit board issue where a cold solder joint on the heater relay pops.The water does not heat sufficient to evaporate any longer. Consult your manual for self diagnosing trouble shooting codes or go to appliance aid.com.
If the board connection is the issue I have repaired several, however Bosch recommends replacement only and sometimes supplies the parts free.
Aug 14, 2008 | Bosch SHU5315UC Dishwasher
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
223 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
