Question about Minolta AF102 35mm Point and Shoot Camera
Film I bought the Minolta AF102 35mm camera at a resale store and it is in perfect condition but the film wont advance
    President:
  • 1,114 Answers
I am guessing that the film is supposed to wind itself on when you close the camera? If you open the camera you may see that the film "leader" has not been drawn into the camera. When you load the film pull a small amount of the film (1 or 2 inches) out from the canister and place it into the (usually) right hand side of the camera where you will see the gears waiting to engage in the sprockets to pull the film in. The film should also lay flat across the rear of the camera where there are gears top and bottom that should engage with the film.Also check you have fresh batteries.
Posted on Jul 26, 2007
6ya staff
SOURCE:
Minolta 700 film advance lever was working, then it wouldnt wind, now it is stuck.
Use or buy a brand new battery from store that sell lot of them.
Do not get from store that only has a few, meaning they have been sitting there for years.
[email protected]
Feb 14, 2014 | Minolta X-700 35mm SLR Camera
Film advance lever wont move
Do you have a film in the camera? If so is it all exposed? Best thing to do is press the film rewind button and try the lever at the same time - this will eliminate stuck film issues as it removes film tension from the system. If this does not solve the issue then you need someone to have a closer look.
Jan 29, 2014 | Minolta X-370S 35mm SLR Camera
My minolta wont load the film
There are contacts that "read" the film. Try cleaning them. If that does not work, check in the manual where to make the ASA in manual mode. That means ever time you load film, you have to check to make sure your ASA of the film matches the camera. If that work, you are good to go. These cameras are from the 90's.
Dec 30, 2017 | Minolta Maxxum STsi QD 35mm SLR Camera
Minolta X-7A - the film advances, but the counter
The film counter moves without the film inside the camera.
You will need to replace the film counter assembly.
Jun 14, 2010 | Minolta X-370S 35mm SLR Camera
Help with minolta x-300s, i cant seem to move the film winder
Well, here's the most likely things going on:
1. dead battery. Your X-300 has an electronic shutter that needs battery power to work. Try fresh batteries and check the battery contact wires for corrosion.
2. End of roll. If you have film in it, try the silver button on the bottom. rewind film and try another roll of film. Before you put in the new film, try the advance, click, advance, click thing.
3. Not all rolls of film are perfect. Some are shorter than they should be, some hang up in the canister.
4. The Minolta X-series were well known to have a problem. Two cheap capacitors on the later models would die, locking up the camera. One is under the top plate and the other under the bottom plate. These caps need to be replaced. I suggest you send it to a repair shop for that. Check prices. Garry's camera repair in Niles, IL does a very economical repair on these. It runs about $50 and $8 for return ship. He will also Clean, Lubricate and adjust it.
You could also buy another 300/370 on Ebay, as they're inexpensive these days.
Best of luck. Hope its just the film or batteries. You might also consider joining the Yahoo Minolta groups.
Jan 19, 2010 | Minolta Photography
The film wont advance
remove and reinsert battery.
be sure you pulled the film all the way across the back.
be sure the door latches.
be sure camera is on.
try the rewind button, it may think it has film in it, ready to rewind.
Still no good? film advance motor may be dead. If so, it needs repair. Lucky for you, the Maxxum 50 goes for cheap on Ebay. You can get another at a good price.
lightspiritphotography.com
Oct 03, 2009 | Konica Minolta Maxxum 50 QD with 28-100...
Auto rewind on my Minolta camera
Broken gears in Advance Assembly.
Needs service.
Mar 22, 2009 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Minolta maxxum 5 jammed film-chamber lock
i just found it after looking at the manual again. it didn't work for me but maybe it will work for you.
go to http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_5/dynax_5_inst_e.pdf
and page 61 (actually page 121 of the manual but page 61 if you type in the page at the bottom of acrobat reader).
when i tried this it made the noise that it wanted to unlock but it didn't.
good luck!
~gobygirl
May 11, 2008 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Film Advance
You rewound the roll to fix the camera and now you want to advance over the exposed film to get to the unexposed part? Not a problem, just put the camera to full manual and load up the film, now cover the lens with the lens cover and go into a dark closet and start shooting and advancing until you get to the unexposed portion of the film, there you go. You know you can get 24 exposures of 35mm film for 99 cents and the 99cent store?
Feb 15, 2008 | Konica Minolta Maxxum 4 / Dynax 4 QD 35mm...
Minolta AF102 35mm Point and Shoot Camera Logo
185 people viewed this question
Top Minolta Cameras Experts
 Larry
Larry
ray gallant
ray gallant
Malcolm Fowler
Malcolm Fowler
Level 1 Expert
Are you a Minolta Camera Expert? Answer questions, earn points and help others
