Question about Motorola Mobility RAZR V3i Cellular Phone
My hand set has a stuck volume botton and can't make calls
How do i take it apart to clean it?
    Problem Solver:
  • 10 Answers
Take the back cover off and you will find small special screws with a little insert in the middle much like a star screw you need a special set of screws to remove them, you can buy it for under $10 at a **** smith stoer or electrical retail outlet.
Posted on Jan 29, 2009
My power shuts off after 2-3 seconds
Hi:
This usually an indication of a power supply problem, have the PS checked for bad capacitors in the output section of the PS.
Jan 24, 2011 | Sharp LC-15AV4U 15 in. LCD Television
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
FIfa 09 Keyboard Problem, When I press 2 directional buttons plus shoot, pass e.t.c it isn't working.
i have the same problem with fifa 10 Sony Vaio VPCEC1M1E when i play with other usb keyboard its working but with my laptop keyboard ist working..
Aug 27, 2009 | Sony VAIO VGN-N130G/W Notebook
No Volume on incoming calls, alerts & sound in windows media.
you go to profile in that you change ringtone settings
Jun 03, 2009 | HTC Touch Cellular Phone
I dropped my Blackberry Curve and the phone clicks...
the volume button may be stuck in a weird position on the inside. you may want to take it apart and clean the inside and reassemble. if you cant then a local repair shop may be able to do it for you
Apr 27, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
AIWA shelf system volume button
I'm sorry but I don't have a listing for that model number. Many of hte Aiwa units use what is called a digital encoder. A call to Sony with the model number should get you the part number as well as the cost and availability. Aiwa is a brand of Sony.
Dan
Dec 15, 2008 | Aiwa NSX-DS55 CD Shelf System
Ilo 32-hd
ILO TELEVISION TURN ON AND OFF BY IT"S SELF, IF I HOLD DOWN THE VOLUME BOTTON IT COMES ON,LET THE VOLUME BOTTON GO NO PICTURE
Aug 29, 2007 | iLO 3200 32 in. LCD Television
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
