Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
We have a fisher Pakel dd603 2 drawer , the top draw wont close so we r trying to remove it to see what is blocking it can't figure out how to take top draw out
  • 145 Answers
Hi!
There are two small clips down in the front of each drawer, one on each side. You depress these clips/tabs which are attached to the drawer slides, and then the drawer can be lifted away from the rails. You need to be very careful not to damage the hose/wire harness guide behind the drawer.
What may have happened is one of the "spring clips" on the rear of the rails has popped up when the drawer was open so the drawer will not have that "snap shut" feel you are used to when the drawer is almost all the way closed.
If you require more assistance, please ask.
Posted on Jan 29, 2009
FISHER PAKEL DD605SS TOP DRAWER WILL OT RUN AND THERE IS NO ERROR CODE
If the power is connected and you are able to program the wash cycle, then it appears the drawer close sensor is failing. The controller is unable to detect drawer close and start the wash cycle. Need to replace the sensor or clean it. The location is shown on page 10 item 5 (tub home sensor) in this parts manual
http://data.manualslib.com/pdf/6/519/51826-fisher__paykel/dd603h.pdf?e53609423d7a330cba24becd37b5c6f1&take=binary
Mar 16, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
The time on now shows 107 instead of 127 min. drawer Fisher & Pakel double
your dishdrawer is in ECO mode. Press the ECO button on the program panel on top of drawer lid. This should restore the Heavy wash time to 127min.
Mar 29, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
My Fisher Paykel DD603I top draw whines when it is first turned
The lid seal on the top drawer is faulty and needs replacement. It might be cut or damaged and is obstructing the drawer from closing. THis also may have caused the flood switch to trip as water can leak if drawer is not sealed.
Nov 29, 2012 | Fisher and Paykel Dishwashers
Need to remove upper drawer Fisher and Pykel dd605ss
Open the top draw. On each side of the draw at the bottom / front, is a clip that releases the rails that the draw slides in and out on. Press the clips in to release and slide it back (into the machine as if you were closing the draw). Do this one at a time and then lift the draw slightly and rotate the draw anti-clockwise direction (due to the plumbing) and lay the draw on its left hand side. The draw is out!
Oct 18, 2012 | Fisher and Paykel DD605SS Stainless Steel...
Fisher Pakel dish drawer sends F1 alarm flashing. It usually happens when there is a drop or change in water pressure. Have had 3 repairs on this disappointing product. Only repair person for Fisher...
F1 is a flood fault ir happens when the machine detects water on the base of the unit, to clear this fault you can remove the bottom draw and use a towel to clean up the water this should clear the fault, But usually there is only water on the base if the lid is not closing properly, this can happen due to you putting long utensils in and the lid cannot pull down or you have faulty lid actuators witch is probably the case and they wont pull the lid down correctly, So if the lid wont come down properly water splashes over the top and floods the base. :)
Jul 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
My top drawer of my Fisher and Paykel dish washer wont close tight. It seemed to be jammed and not closing unless it was pushed closed hard and then it jumped a bit now wont close tight and has no...
Make sure the unit is level. Remove drawer. On the inside of the cabnet there are the drawer runners on iether side. Behind these there are a pair catches. If one or both of these are latched back when they shouldn't be, ie. when the drawer is open, they will obstruct the drawer from closing fully and fail to hold it closed.
Hope this helps
Dec 13, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
The top drawer of my Fisher Paykel two drawer dishwasher will not close all the way. Something appears to be stopping it. How do I fix it?
To find out what might be blocking it, you can remove the drawer. There are two tabs one on each side of the drawer near the bottom front. Push those in and pull the drawer out. You can lift the drawer up and push the slides in to get them out of the way. Then you should be able to see into the cabinet and what if anything is stuck behind the drawer
Apr 22, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & paykel double dish drawer top draw just beeps...
The controllers get very brittle & can break away from their housing, the reason it's rapidly beaping is because it thinks the door is open. PLEASE TURN IT OFF FIRST AT THE POWER POINT. Take the front draw panel off by pulling the plugs situated on the front behind the draws, the controller is at the top right hand side if it is loose then thats the problem, double sided tape will work but lots of it or try a wedge type arrangement. I know this is an old post but people refer to these for solutions much later.
Mar 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to take or remove drawers out of 2 drawer Fisher Pakel
Hi, welcome to FIx Ya...
1. Unplug machine.
2. Slide drawer open, remove two pegs that secure front panel to drawer (one on each side of drawer)
3. Slide front panel down and out, remove green ground wire.
4. Depress tabs that hold bottom plastic cover on bottom of drawer and remove entire cover, being careful not to break the tabs.
5. Disconnect tan water fill hose from rinse dispenser.
6. Disconnect two wire harnessess at control board.
7. DIsconnect drain hose from pump base. (might want to put a pan underneath to catch water)
8. Depress tabs on hose/harness coupler at bottom rear of drawer and dis-engage the coupler.
9. Lift drawer off slides.
Jan 13, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher & pakel dd-603ss top drawer wont drain
Have you cleaned the drain filter ? If not, clean that ( it is beneath the rack where the utensil bin is normally positioned and accessible by lifting up the plastic door..If that is clogged up then your drain flow will be restricted. Also, check to make sure the drain line is not restricted ( pinced or clogged). .And yes , the drain is pumped out. If these tips do not get you going, please write back and let me know.. will help get your dw going ...
Regards
Oct 10, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
211 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
