Horizon CT7.0 Motor Control Board Logo
Roger Boudreau Posted on Jan 25, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Horizon CT 7.0 treadmill slows down when i step on it
It runs ok when turning on it's own but as soon as we step on it it slows down. the belt on the motor looks ok and tight. the belt that we run on is well lubed.
ernesto cuadra
Level 3:
Top Expert:
  • Horizon Master 12,223 Answers
  • Posted on Jan 25, 2013
ernesto cuadra
Horizon Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4080057
Points
34431
LUBE THE deck belt and rollers bearing . This happen because you must lube about 150 miles aprox. See the video and fix it. However if the problem persist. Time to replace the old board deck.
God bless you
2 Related Answers
Anonymous
  • Posted on Aug 22, 2010
SOURCE: horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Dec 31, 2012
SOURCE: horizon DT850 treadmill belt won't move
Step 1:
please see the video and lube too the rollers bearing. Happy new year and God bless you
Step 2:
test the input voltage motor, if there are voltage in the motor, the motor NEED repair, see the diagram attached, and see my personal TIPS for motor help.
Step 3:
test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the diagram attached.
My quick speed keys - up or down wont work on my CT 81 horizon treadmill. Any advice?
I have the same problem on a model LS760T. Also the Stop button is inoperable.
1helpful
I have a ct83 horizon treadmill, recently there is a bubble in the walking belt that makes noise
Because of the continues usage, It will get spark and make noise. This can be prevent by painting or just put some oil to the engine.
Error code 321
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
1helpful
Horizon Treadmill won't run?
Check this attached link for trouble shooting information
Code 701 06 comes up
I have a T91 and first had the Lube Belt error. After lubing the belt and upon turning the unit on while holding the Stop (Not necessary according to instructions by horizon but I did it while powering up anyway) button down, the 701 06 was momentarily displayed. The unit then displayed the Lube Belt warning again. Lemme know if you hear anything, I am working on it.
Burt
Horizon treadmill won't incline
Step 1:
Clean the motor, lube the gear+shaft
Adjust the small POT for a little.
RUN the software calibration for troubleshooting. see the diagram
Step 2:
Step 3:
Step 4:
he Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Horizon AFG 13.0 AT Treadmill slows down after 15 min and a grinding noise from the flywheel
first unplug the trendmill and expose the motor. on the motor is a disc shape cover, remove it and you see ampreture, take a eraser on a pencil and clean the ampreture. Do this by rubbing the eraser on the ampreture and rotate it while your cleaning it
After lubing the belt on my Horizon T101 it started tripping the breaker after 5-15 minutes of use. It never did this before I lubed it. Any suggestions?
Step 1:
1) the old board deck belt is time to replace it
2) However you must test a) the main motor see my personal TIPS for motor help b) test the output voltage board, for input voltage motor if there are NOT the board is faulty. see the diagrams attached.
God bless you
Step 2:
Step 3:
Horizon CT-81 treadmill needs lube
100% Silicone Oil; 1000 weight viscosity :)
Top Horizon Exercise & Fitness Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
