Question about Jensen VM9410 Car DVD Player
Player won't turn on..
A couple days ago my windows were left open and I was away from my car. A friend went to cover them and accidentally set off my car alarm. He got annoyed of this rather quickly and decided to just unhook the battery.. Ever since then I can't get my player to respond to anything... I have no idea what to do.. I don't really know how to reset it, I think I accidentally threw away my manual. All it does is beep when I push the Power button.. Any Help would be greatly appreciated!
  • Brady Seaman Jul 26, 2007
    sorry i forgot to put this, the reason he was covering my windows is because it was raining..
Remove the head unit , its a 10 amp fuse in the battery wire its possibly blown
Posted on Jul 30, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Syntia out of service code?
If it is under warranty ,call the manufacturer .There are many causes to the service code , coffee beans ground too fine ,setting for 3 beans may be too much if the beans are small, try setting with one bean...
Valve, round cover , spring loaded , on top of brew group dirty, metal valve pin may be covered with deposits from coffee oils . check manual or call a service center , screen of bottom piston plugged with coffee oils , to silver screen plugged with coffee oils .
none of the super-automatics like oily , shiny or over roasted beans .
Dec 19, 2013 | Saeco Syntia Espresso Machine & Coffee...
I can't logged in my facebook account....even in other browser but my brother's facebook account can log in..... whenever I log in....i get this some kind of notice "Something went...
This happened to a friend of mine a couple of weeks ago. First, I would suggest restarting the computer. My friend simply waited (it was a day) and the error went away. It seems to be an error on Facebook's side, since trying to login onto that account anywhere has the problem (another computer, phones, etc.). Sorry I couldn't give a definitive answer, but if in a day it's not back to normal, you can always contact Facebook directly at 650-543-4800 (granted this phone stinks what from I've heard, but it's better than nothing).
Jun 19, 2011 | Check Point Computers & Internet
About 2 weeks ago my check engine light came turned on so i drove home and told my dad about it but when we turned the car on it did not flash. But the the next 2 days it stayed on and the next morning...
Any time you get any check light, you should
be at a repair in a couple of days, or at least
check for codes. Still need it diagnosed and
repaired in a week
Otherwise you waste gas,polute the air or could
cause some damage,as you don't know what the issue
is that set the light
The fact the check light went out, doesn't mean
the problem went away.
Don't clear any codes you find,their needed to diagnose
the system faults
Apr 05, 2011 | 2006 Mitsubishi Eclipse
I have no power to my car even when i try to jump it
you may have left a important wire off the battery,or ground
Jul 19, 2009 | 2000 Dodge Intrepid
Won't reset, turn on or read in computer. Blue light isn't on.
same problem this fixed it right away I was suprised
posted on Feb 25, 2009 abeales
If you have windows set to do automatic updates, you most likely had a windows update installed that caused this conflict with Win Media Player 11. No fix has been posted by Microsoft yet, so the only workaround is to Uninstall/Rollback Windows Media Player 11. Goto <Control Panel<Add/Remove Programs and remove Windows Media Player 11. Follow prompts, restart computer when prompted to. Also uninstall Windows Media Player 11 Runtime application following same procedure above.
This will roll your Windows Media Player back to version 10 or 9, whichever you had installed prior to version 11. You will need to re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You probably need to upgrade your firmware at this point, follow the instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative for the screwed up hotfixes that Microsoft puts out on a regular basi
May 20, 2009 | Creative Labs ZEN V Plus MP3 Player
Dell Inspiron E1505 shows green pixels instead of black
the color pixels are different sections in the screen and the green section might be cracked
Apr 24, 2009 | Dell Inspiron E1505 Notebook
LOGITECH COMPUTER MOUSE JUST STOPED WORKING
On the bottom of the mouse is a small door and it takes two AA batteries.
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Jan 06, 2009 | Computers & Internet
Sandisk won't turn on
It needs to be completely dried on the inside. Carefully remove the outer cover and then leave in a fairly warm dry place for a couple of days or use a blow dryer on low(no heat setting) this needs to be done right away before the water corrodes the components in the device.
Hope this helps. Good Luck!
Nov 16, 2008 | SanDisk Sansa e250 MP3 Player
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
DVD-LS5
had same problem here but then i found a soloution might help you helped me
I purchased my LS50 over 16 months ago. I had a H03 error before and it went away after sitting on the shelf for three days. It worked ok for another couple of months and then stopped again. The screen says reading but the motor is not spinning. , then i spotted that the laser lens is in the wrong place. When at resting location, the lens should be parked near to the spindle in the middle. The mechanism to move the lens backward and forward sometime get stuck at the end of its travel - furthest away from the spindle. If your player is out of warranty, then you maybe able to try this. Open up the bottom cover by taking out the screws - 10 or so. This will reveal the lens and motor module. Flip over the model and you should see the gear and shaft for the lens. Move the gear so that the lens move towards the centre. Click the covers back into place , reconnect the battery and try. If it works, put all the screws back. Mine was fixed this way but this is not a gaurantee that this will work on yours. Good luck.
Forgot to mention. You can also clean the gear shaft in case there are small particules stuck to the grease and affect the movement. After cleaning, apply a tiny bit of grease just to lubricate the moving shaft. Not too much. I am glad that the instructions help.
it helped plenty of friends hope it helps you
Feb 20, 2007 | Panasonic DVD-LS50 Portable DVD Player
Jensen VM9410 Car DVD Player Logo
98 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
