Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Picture the picture on the tv is faded how can i fix it?
  • 2,071 Answers
Faded pictures it is caused by leaky or short capacitor it could also be power supply problem causing the optic engine and light not to work correctly, or you could have a bad DM board, or a bad light engine sounds like a bad DM board find six of the fourteen known-problem caps to be visibly bulging -- both 3300s and two of the four 1000s on the PWR PWB plus two of the four 1000s on the FMT PWB (see photos below). Ironically of the four 1000s on the DM PWB, which I have heard are the most common to go bad, were bulging and I considered skipping these as the DM it is the toughest board to extricate from the chassis, however I figured I had come this far and I would just as soon replace all twelve 1000 uFs as the parts cost $0.23 and I really never want to have to do this again.
If I had to bet, the two 10V 3300uF caps on POWER board, which were actually leaking black goo, are the actual culprits, but with four of the 1000 uFs also bulging it is probable only a matter of time until they failed as well.
Here is the POWER PWB with the known-problem caps (C9A37, C9A38, C9A51, C9A52, C9A61 and C9A62) highlighted:
here's the FMT PWB with the known-problem caps (C8F19, C8F21, C8F22 and C8F27) highlighted:
and the DM PWB with the known-problem caps (C81A2, C81A3, C81B3 and C81B4) highlighted:
Here are close-ups of the bulging caps (C9A37, C9A38, C9A52 and C9A62) on the POWER PWB:
And here are close-ups of the bulging caps (C8F19 and C8F27) on the FMT PWB:
Hope it may help you; Regards;
VOTIT
Posted on Jan 29, 2009
    Problem Solver:
  • 61 Answers
Clean the lens and mirror you have to take of the screen al the screews on back and a few on the front
How to fix a Sharp Aquos LC-40C32U Picture
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 01, 2015 | Sharp Televison & Video
Sony KPR-53EXR15 pictures fades in and out
Sounds like possibly it could be connection related between any AV/Cable ports. Worst case would be the capacitors of the motherboard leaking. It's possible to fix anything. Just make sure you have the knowledge and the right equipment.
Mar 31, 2017 | Televison & Video
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
My fan is not working picture fades out when over esa plasma tv
need to bring to your tv service center before it blows out and becames more expensive to fix only a tv tech will be able to fix it,,
Dec 16, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Picture comes on then fades to blue
Check the info from this website to see if you are able to fix your TV. You should turn the blue screen control down slightly counterclockwise. If that did not work, then more likely you have a video amplifier IC defective or a blue CRT.
Dec 19, 2008 | Sony KP-57WS500 57" Rear Projection...
TV picture fades, then shuts off
There are some components in the scan amplifiers, and or the power supply area that have become unstable. This can happen with age and use. It is impossible to make an accurate assessment without actually troubleshooting the set.
You need an experienced TV service tech that is strong on troubleshooting, has the service manuals, and has the proper set-up to work on your set. I would recommend the factory service rather than an independent service tech unless you know for sure that the independent service tech can handle this type of repair.
Considering the age of the model of set that you have, I would be looking at replacing it rather than fixing it. Because of the age of the set the reliability will be decreased.
Jerry G.
Jun 10, 2008 | Samsung TXF2899 28" TV
I have sound but no picture?
i setup a remote code on the remote so the tv goes on /off and the volume but no picture on screen how when i put the dvd player i can see the movie but noy regular tv please help
May 08, 2008 | RCA D52130 52" Rear Projection Television
Faded Picture
I would have to say it does sound like the CRT is reaching its end. The thing that points this out that the picture gradually gets a little bit better as it warms up. It most likely isn't worth the cost to fix it.
May 07, 2007 | JVC AV-27230 27" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
137 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
