Question about Car Audio & Video
I recently was told that the intake manifold for my 2004 Mazda 3i 2.0L engine needs replaced! The car has 47,000 miles on it. Regardless of my dismay and disappointment, I have to get it fixed! The dealer gave me the part number of LF62 13 100J. However, I cannot locate the part on the Internet. If you can help, I would greatly appreciate it! Clickety clank in Long Beach, CA Thanks, Dennis
  • 27 Answers
Okay dennis you dont have to use the oem parts okay go to xs_power.com kk they should have what your looking for
Posted on Feb 06, 2009
2004 mazda tribute idles high and manifold glows red hot after only 20 minutes after running
When you say manifold, I assume you mean the exhaust manifold. If its the one you can see (there is an exhaust manifold on the back of the engine also for the rear 3 cylinders) its a clogged or fried catalytic converter. There are a couple of catalytic converter cleaners on the market you can try, but most likely it will need to be replaced. Was there another problem recently i.e. bad coil pack etc?
Feb 24, 2013 | 2004 Mazda Tribute
What is causing my 2005 Mazda 6 sport wagon to run jerky and not accelerate smoothly.
If it started only 3 days ago, go to your auto parts store and the next time you fill up, add a can of Sea Foam. If there is a gas station near you which sells gasahol-free gas, fill it up with that, then take it out on the interstate and kick it into passing gear several times (I hope you don't get a speeding ticket).
Nov 09, 2017 | 2005 Mazda 6
Where is the map sensor located on a 2004 rodeo
check the right side of the intake manifold or the right rear of the intake manifold...
Feb 03, 2010 | 2004 Isuzu Rodeo
Getting code P2070 which goes of by itself.
DTC P2070: Intake Manifold Tuning Valve Stuck Open Bank 1
Probable cause:
  1. Sensor or solenoid faulty
  2. Connector terminal contact damaged or corroded
  3. Wire harness fault - Check for correct voltage, open, short to ground or short to voltage
  4. Update control unit software - Check for the latest control unit update
  5. PCM or ECM faulty
Jul 13, 2017 | 2004 Mazda RX-8
AT light on 2004 Mazda 3i
the solenoid valve deals with emissions. ? strange. I'd say it may be an issue with the turbine speed sensor on the transmission. Does it have enough fluid?
Feb 22, 2009 | 2004 Mazda 3
2005 Mazda 3 idles rough at stop light and sometimes dies
The problem is a faulty solenoid in the vapor recovery system. The solenoid is sticking open and allowing fumes from expansion of fuel in the fuel tank to enter the air intake and smother the engine. This is how the Mazda service tech explained it to me. It is a known problem on the Mazda 3 in various trims which Mazda refuses to acknowledge. Usually the check engine light comes on and the engine diag code reads mass airflow sensor, which is incorrect. I dealt with this for 6 months on my wife's 2005 Mazda 3i before the dealership figured it out. My cousin bought a 2007 Mazda Speed 3 which developed the same problem after a few months and was cured by the same fix.
Jan 10, 2009 | 2005 Mazda 3
2004 Mazda 3i 2.0L -- Intake Manifold
I have had the same problem at almost exaclty the same milage. 2004 Mazda 3 3 door hatchback (5 door sedan). I was told by the service manager that there is a valve in the manifold that fails and starts flapping, sounded just like a collapsed lifter. I think this should be covered under warranty. If not the mfg warranty the emissions? .. good luck.
Nov 25, 2008 | 2004 Mazda 3
Problems with cold engine
It is the head gasket. Have that replaced and you will be fine. You have an air leak. I was told by the mechanic at mazda that the anti freeze eats away at the gaskets. CRAZY, but it works. I still have an issue with my 2001 Tribute revving while in park. Its always something.
Oct 24, 2008 | 2001 Mazda Tribute
Car Audio & Video Logo
109 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
