Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Rpc server is unavailable
Have had this printer & it has worked fine, tried to print something & it said i needed to add printer, placed the disk in & tried to fix error & now i get rpc server is unavailable. any suggestions to what is going on with it? thank you
  • 3 Answers
The computer displays error "RPC Server is unavailable".
It may be that you have a static value in your registry's field PagedPoolSize, we need to make this "0" (zero). check the steps ->HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
Posted on Mar 18, 2009
  • Angel Wings Mar 13, 2013
    Can you explain, what exactly i have to do??!! I've got the same prob!! :/ But i didn't understand anything you said, in another words i don't know what to do! :( Can you explain?
Rpc server is unavailable when installing printer
According to the error message, I assume that the spooler service cannot find out the printer on the network.
You may set the startup type of Printer Spooler service to Manual or Delayed Start for a test.
You could go to Customer support- just dial +1(800)243-0051 Toll Free.
Apr 27, 2017 | Office Equipment & Supplies
I have installed hp laserjet 1000 on server 2003.I have shared this printer to my network.I am even able to print from client machines remotely.But one of my client machine shows 'The RPC server is...
RPC service may not be available or started on the client machine.
To start/ enable it go to 'Run Command' and type 'services.msc' , locate REMOTE PROCEDURE CALL (RPC) and start the service.
Dont forget to appreciate the solution if I could have been of any help!
Dec 07, 2010 | HP LaserJet 1020 Printer
Cant install driver with "rpc server is unavailable" and also shows both the se and se sec family in device manager.
Have you gotten an RPC error lately? They look a little like this:
- "RPC Server is Unavailable"
- OR "The RPC Server is too busy to complete the task"
- Here's the best one, "Access denied"
This is fun stuff. Unfortunately, an RPC error is one of the most common errors out there, and most of us don't even know what RPC is.
What is RPC?
RPC stands for "Remote Procedure Call." This probably still doesn't tell you much. Let's see if we can put this in non-technical language. RPC is the go between of your computer and server. This is what allows your computer to access a network.
RPC has two main parts to it: the client and the server. When the client (the program requesting something) sends a message to the server (the process that takes the order or performs the task), it is being asked to execute a certain procedure. The client waits for the server to process the call before resuming the execution.
Why Won't the RPC Server Work?
Usually, the RPC error pops up because there is some sort of miscommunication between the computer and the server. Most of the time, the wires get crossed somewhere due to Internet components that are not configured or activated. Sometimes it is just a matter of adjusting the Internet Firewalls or Proxy Server.
Quick RPC Error Fix
One way to investigate an RPC server error is to verify that you have enabled the DCOM Tunneling is enabled and not being blocked by any third party Internet Security programs such as AVG, Norton, McAfee, etc.
To do this:
1. Go to Start and Run
2. Type in DCOMCNFG
3. Click on Component Services
4. Click on Computers
5. In Computers, right click My Computer
6. Choose Properties
7. Go the Default Properties tab
8. Check the "Enable DCOM" tab
9. Go to the Default Protocols tab
10. Click Add
11. By the Protocol Sequence move the down arrow to Tunneling TCP/IP
12. Click OK
13. Click MoveUp button until Tunneling is at the top of the list
14. Now you may select SPX and Remove
15. Click OK or close the program out
16. Restart the computer
When You Need Help with the RPC Error
The RPC Error is such a common error, it seems like it should be easy to fix. However, the DCOM Tunneling fix is only the beginning of troubleshooting an RPC server error. The good news is that you really don't have to do anything when it comes to an RPC error if you maintain your computer with registry maintenance tools. Try researching the benefits of a registry cleaner to fix RPC errors.
Optimize-Your-PC, with its Advanced Registry Cleaning Technology, will repair an RPC error, and Speed Up Your PC, all in under 2 Minutes.
Jan 21, 2010 | ATI RADEON 9200 Graphic Card
Server-error-service-unavailable on my hp printer
See this link, I had the same problem and it fixed mine.
Mar 04, 2009 | HP Photosmart C3180 All-In-One InkJet...
I am trying to install the canon selphy ES20 printer...however when I attempt to add the printer to the computer, it does not recognise it and says there is an error with installation and "RPC server...
Hi, this is a solution for you. Follow the steps below and your Canon printer should be working.
  1. Unplug the printer from your computer
  2. Download and install the drivers from this link
  3. Plug in you printer and just let your computer recognize it and do it's thing.
Good Luck!
Jan 31, 2009 | Computers & Internet
Follow those instructions, but ignore that it is HP. The instructions should work for your Dell printer as well. If they don't work, let me know and I will pursue your issue further.
Jan 09, 2009 | Dell Dimension 2400 PC Desktop
The RPC server is unavailable
Goto Run and type services.msc...and then there u have to restart the RPC service..
Dec 11, 2008 | Lexmark Z611 InkJet Photo Printer
Server failed
Is this an" RPC Server Unavailable" error under windows? Be precise w/ your question.
Aug 27, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
HP print spooler problem and error 1068. Want my printer back!!!
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at
Apr 04, 2008 | Epson CX8400 All-In-One InkJet Printer
Solution #1posted on Dec 23, 2007 by Silan
Try :- printer_installation_problem a Command Prompt window(click start--
-->run--->type cmd and press OK)
2.key sc config spooler depend= RPCSS (note
the space after depend=) and press Enter.
Try reinstalling the printer.
1. Start / Run / MSConfig / OK.
2. Select the Services tab.
3. Make sure that each of the following
services is checked:
Plug and Play
Remote Procedure Call (RPC)
Remote Access Auto Connection Manager
Remote Access Connection Manager
4. Press Apply.
5. Press Close.
6. Press the Restart button.
Try reinstalling the printer software. If the
issue does not resolve Please get back me.
Dec 20, 2007 | Lexmark Z611 InkJet Photo Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
881 people viewed this question
James Cagle
James Cagle
Jim Keysor
