2007 Hummer H3X Logo
Posted on Jan 29, 2009
07 h3 navigation
Where is the navigation disc located and how is it removed?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2196
Points
8
It is actually located behind the navigation screen.
Turn off the radio.
Press and hold the CD eject button until the display unlocks (about 10 to 15 seconds).
Let screen move outward and rotate downward.
Press the DVD eject button just exposed behind the display.
Remove DVD, insert new one.
Rotate display upwards and press gently on all four corners to slide and lock display back into original position.
Turn on radio, navigation DVD should start update process, let it finish.
? About Nav for 07 Lincoln navigator l
disc says it may be dirty try
well if it is bad get a new one.
end.
My navigation screen on my H3 '07 went black. ...can still push to get radio stations, but no image
The screen has failed, you need it pulled out and sent out for repair.
I have a 2004 Acura RL, navigation screen reads "check nav disc". How do I fix?
Your Navigation disc usually is in the CD player. Most require the First Disc to be the Navigation disc. Now if this disc was removed or if someone changed the position of #1 disc and inserted something else, then that is why you have your message.
It is also possible that removing the Battery from the car may cause it to lose the programming in the Navigation. It may simply need the Navigation disc to be reread.
1helpful
Where is the fuse box in my 2009 Hummer H3?
my ;07 fuse panel is under the hood - just in front of the battery - says Hummer on it...
6helpful
Hummer h3 air/heat blower not working
Your fan relay, located under the glove box on the right side has gone out. I just replaced mine, a 07. It's got a white bar type plug in on it and you will need some small 1/4" sockets to pull it out. just order one on line there under $30.00 and it will fix your problem .
3helpful
How do you remove the front tow hook brackets on a 07 hummer h3
put the bolts back in and tap them with a hammer it will push the bracket out and then take the bolts out
2answers
Loading 7.3 navigation dvd
The DVD for the navigation is not loaded into the 6 disc changer. Push the passenger seat all the way forward and up. Get in the back seat and you can access it from there. There is a cover that might need to be popped down.
Top Hummer Experts
ZJ Limited
ZJ Limited
ROBERT GARCIA
ROBERT GARCIA
Are you a Hummer Expert? Answer questions, earn points and help others
