Question about Frigidaire FEF336BC Electric Kitchen Range
ES510 frigidaire range shows flashing F7 an 10 codes
I was washing around the controls with soapy water and the codes appeared. I assume that water got into a switch. Will it dry out and reset, or is something fried? I've shut off the power to the range. Thanks. Paul
  • 95 Answers
Allowing it to dry with warm air and power off should fix it You can get an dust off can from photo store and blow some of the water out to speed things up could take 24-36 hrs depending on tempature.
Posted on Jan 29, 2009
Getting an F15 error code when trying to start Oven.
Error code f15 'Frigidaire FEB30T7FC Stainless Steel ...
www.faqqq.com/.../error-code-f15-frigidaire-feb30t7fc-stainless-steel-ele...
Error code f15 'Frigidaire FEB30T7FC Stainless Steel Electric Double Oven ... I'mtrying to open up a Unity3D game.exe that is on a remote computer through my main desktop. ... How 2016 will be the start of your virtual reality future - CNET.
Kenmore range shows f15 error code - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Range, Oven & Cooktop Repair
Oct 31, 2010 - 10 posts - ‎5 authors
Kenmore range suddenly started flashing f15 error code. With Thanksgiving just around the corner, i need help with this repair. Thanks.
Dec 30, 2015 | KitchenAid Kitchen Ranges
The cooling fan for the stove top stays on due to a burner showing HE but not on or hot
Hello Chris Lowman, thanks for your inquiry!
I understand that your Frigidaire range, FGES3065KFC, is flashing the error code "HE". However, it appears "HE" is an invalid error code. We should try resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes.
If resetting the power does not correct the issue and you continue to receive an "HE" I would recommend reaching out to a professional. He or she could come out and perform an accurate diagnosis on your range to assure the repair is completed properly. I hope this information is helpful. -Matt
Nov 04, 2014 | Frigidaire Kitchen Ranges
How to use the self clean feature for a Frigidaire FES 355 ASF
Hi Anonymous, this is AP!
I understand you are interested in the self-clean process for your Frigidaire slide in range, model FES355ASF. Start by removing all excess spillovers in the oven cavity before starting the self-cleaning cycle. To clean, use hot soapy water and a cloth. Large spillovers can cause heavy smoke or fire when subjected to high temperatures. Clean any soil from the oven frame and the door liner, but avoid cleaning the oven door gasket. These areas heat sufficiently during self-cleaning cycle to burn soil on. Clean with soap and water. Remove the oven racks, broiler pan and insert, all utensils and any foil. These items do not withstand high cleaning temperatures
Make sure the clock shows the correct time of day. Push the CLEAN button "---"will appear on display. Push the up arrow button until "3:00" appears for a 3 hour clean cycle or push the down arrow until "2:00" is displayed for a 2 hour clean cycle. Once the time is selected and released CLn will appear on the display. The door will then automatically lock and the LOCK indicator light will flash. Do not open the door while the indicator is flashing, usually about 15 seconds. The LOCK display will stay until the cleaning cycle is complete or cancelled, and the oven temperature has cooled to a safe temperature.
In the event you need to stop the cycle at any point, simply push the CLEAR OFF button and the door will automatically lock once the oven has cooled, usually about an hour.
Best of luck,
Apr 03, 2014 | Frigidaire FES355 Electric Kitchen Range
What does a flashing F5 mean on a frigidaire es510 range
Hi there:
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa
Jan 07, 2012 | Kitchen Ranges
Help me with my Frigidaire Es510 Control Self cleaning,Oven with deep well style cooktop It has the time flashing but will not respond and it also has PF on it
The CLOCK pad is used to set the clock. The clock may beset for 12 or 24 hour time of day operation. The clock has beenpreset at the factory for the 12 hour operation. When the range isfirst plugged in, or when the power supply to the range has beeninterrupted, the timer in the display will flash with power failure "PF"
Instructions:
To set the clock (example below for 1:30):1. Press the round "CLOCK" button. "CLO" will appear in the display (Fig. 2).2. Press the round "1" "3" "0" pads to set the time of day to 1:30 (Fig. 3)."CLO" will appear in the display. Press the round "Start" button. "CLO" willdisappear and the clock will start (Fig. 4).
Oct 10, 2011 | Kitchen Ranges
Oven control valve wont shut off gas completely
This could be due to a build up of grease or tiny food particles behind the control tap handle;
1/ Gently prise off the handle ( it comes towards you )
2/ Wash handle in warm soapy/detergent water, till clean, then dry.
3/ Use a lint-free cloth or a sponge with warm soapy water to soak the tap control spindle and a plastic knife to clean off any stubborn bits.
4/ Wipe clean , replace handle part, try turning off.
Jaylo264
Jan 03, 2011 | Brown Stove Works TM210 Gas Kitchen Range
I have a Frigidaire ES510 and I'm getting an error code F10. The error disappeared after pressing a couple of buttons but the beeping would not stop. I turned the power off and back on then after about a...
Hi
Thanks for using FixYa. F10 error in your Frigidaire means temperature runaway. This issue is caused due to failed oven temperature sensor and/or the control board that has gone bad. To check what has gone bad you'll need to take off the rear panel off the oven and test the sensor which is located behind this panel. If the reading is more then 1100ohms then it should be replaced, if the sensor tests fine then it is the control board that has gone bad and should be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 06, 2010 | Frigidaire Kitchen Ranges
Electrical panel went blank. Hence can't operate the oven. Stove works fine.
Hi. Interesting. My Figidaire Gallery Professional gas stainless went blank 2 days ago. Model FGF379WECS. So I'm googling...
Your Service Manual is located at (document #2 in link):
http://www.retrevo.com/support/Frigidaire-GLEFM397D-Ranges-manual/id/2367bh351/t/2/
Part Number
316418704
Description :
Clock/Timer, electronic, w/mini oven, ES510
Rick
May 15, 2010 | Frigidaire Gallery GLEFM397DS Electric...
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Have a frigidaire es510, i am getting an f20 err when I amtrying to use the stove
Hi ,
This is the code for a communication failure between EOC (ELECTRONIC OVEN CONTROL) & ESEC system
1. Test harness/connections P4 (EOC) & P11 (Surface Element Control Board)
2. If harness checks O.K. failure can be caused by faulty UIB, Surface Element Control Board or EOC.
Check on the back of the stove there should be an envelope attached to it that has service paperwork in it with diagrams
It will most likely need a new oven control very easy to replace just remember to remove the power to the unit before you work on it.
Please contact me if you have any more questions.
Mar 24, 2008 | Kitchen Ranges
Frigidaire FEF336BC Electric Kitchen Range Logo
500 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
