Please remove shipping lock from yellow cartdrige
I try to install my new HP CM1312 MFP and already removed all 4 lock at the toner but the printer screen apprear "Please remove shipping lock from yellow cartdrige". What should i do?
  • 2 more comments
  • Anonymous Mar 02, 2009
    same as yours
  • Anonymous Mar 23, 2009
    exactly the same on a MFP
  • Anonymous Apr 27, 2009
    exactly the same.
  • Anonymous May 13, 2009
    samee :S
I'm not sure this will apply to all instances of this, but we had the same problem on a CP1515n. I tried cleaning contacts and waving the cartridge about, to no avail.
I then found a message from an HP employee in another forum saying to swap the yellow with another colour, start the machine and then swap them back. I swapped it with the magenta and the printer went through quite a long initialization process eventually saying "incorrect supplies". I swapped them back and it worked.
Posted on May 18, 2009
  • Ajit Pal Singh
    Ajit Pal Singh Jul 15, 2014
    Dear Friends, before i have same problem with magenta cartridge showing error to remove shipping lock, today i read the comments from this fixya to replace yellow on magenta and I did same then press ok to reset the cartridge then screen show incorrect installation then I again replace in right place then press ok to reset then its work. Really this is useful. Thanks lot.
I had same problem and googled it and found this solution
As per above I have swapped the cartridges around
Firstly the message "Magenta in wrong place" came up but
I persevered and swapped around again and after a loooooonnnng
initialization IT WORKED and started printing
Clearly its just something HP have to stop people using compatibles which I guess it qutie common and designed to make you give up and pay the much higher price for originals
Thankyou to person who put this solution on !!!
Posted on May 21, 2010
Thank you guys so much! I knew the problem had something to do with the fact that my office manager insists on the refillable cartiridges instead of the brand new ones, just didn't know how to fix it until I googled it and found this solution. And it WORKED!
Posted on Jul 12, 2010
If you hold cartridge, label reading towards to. On your right hand there is a little whilte tab. If you push it with your thumb, it will pop a little black tab. do it few times, blow little air if you have the air duster. Intall it and you should be fine.
Posted on Sep 04, 2012
I had the same problem where it said to remove shipping lock. I noticed a small silver tab missing when I compared the cartridges, I removed two screws from the old cartridge, removed the silver tab, needed to bend back into shape and installed on replacement cartridge and it worked.
Posted on Oct 29, 2014
Mohammad
Nilesh
solutions Sep 04, 2012
yeeees thes is gooood anser thanksfor allah then thank you
Nilesh 1 and thanks for all up guys.
Posted on Nov 03, 2012
    Habit-Forming:
  • 31 Answers
I had the same problem...bought a new CP2025 Color LaserJet and when I purchased a new black cartridge after the initial toner that came with printer ran out I also got this error. I bought a new HP Toner cartridge so I took it back and said it was defective and got a new one which worked fine.
Posted on Aug 29, 2010
HP laserjet 100 mfp blue line
I had the same kind of problem with the same printer.
The problem started with yellow toner powder 'leaking' inside the printer and contaminating the printed documents.
After inspection, the yellow cartridge showed what seamed to be like caked/cluttered powder between the magnetic roller and the doctor blade.
I dismantled the cartridge to realise the 'caked/cluttered powder' was in fact a sponge material. The internal 'spongy' toner feeder roller was damaged and little pieces of the material was coming out of the cartridge.
After further inspection inside the printer (all cartridges and drum removed), I found two little pieces of the same material stuck between the kevlar roll and the metallic housing underneath it. (going up, from bottom to top, you have the pile of paper in the feeder -> horizontal metallic plate -> kevlar roll -> toner carousel.)
I used a strip of heavy paper (200g) to gently remove the two sponges, set two clean jobs and the problem was solved.
The kevlar roll is also accessible from the printer's back door, some material may also be stuck in this location.
Nov 06, 2012 | HP LaserJet Pro 100 color MFP M175nw -...
Bought a new macbook air and want to install my Color LaserJet CM1312 MFP. when connected via USB the printer prints. however if i use the set up assistant, the printer is not recognized. can not install...
Deleting the printer and then reinstalling it using the Gutenprint Drivers for the HP 1300 Series in the Add Printer pull down will allow you to print B/W. This works wirelessly over an Airport Extreme, so I assume that it will work wired. I am searching for a solution that prints in color. Amazing that HP and Apple seem content to orphan such a widely-used and relatively recent MFP.
Sep 05, 2011 | HP LaserJet CM1312 All-In-One Printer
I have an Hp CM6030f MFP that said to change the yellow toner. When I changed the yellow toner which was more than half full it is now stuck in calibration mode.
  1. Power cycle the printer and Verify the "Replace Cartridge?? message is still present.
  2. Remove ALL the cartridges (Toner and Drum cartridges).
  3. Power cycle the printer
  4. Install one by one of the cartridges when the printer requests them
  5. Verify that the new cartridge is recognized by printing the Supplies Status Page.
May 25, 2011 | HP Colour Laser Jet CM6030F Multi Function...
Our hp LaserJet 1312 drum head may need replacing. I'd like to know more about the drum and drum head, as well as info. on purchasing and replacing so that we can compare this to replacing the...
the drum is in cartridge with toner. So if you buy new cartridge ( genuine or repaired ) you can use your MFP.
You must have on mind that you have 4 drum/toner units inside - Bk, C, M, Y. To be sure which one is needed to be changed refer to your problem, which I presume are lines and spots on printed paper. i.e. if the lines are yellow, you need to replace yellow cartridge.
The crg. No. are:
CB540A-Bk
CB541A-C
CB542A-Y
CB543A-M
Remanufactured one are from 50USD to 70 USD depending on quality.
The each cartridge goes about 2000-2500 prints/copies.
Hope that helps!
Apr 29, 2011 | HP LaserJet CM1312 All-In-One Printer
The yellow toner keeps leaking out and after only a few prints, I get "replace yellow toner" I am using brand new toner from dell. I believe I am installing cartridge correctly. why would it...
the printer is fixable seems like you need to get another toner cartdrige clean out the area and printer drum and make sure to shake the cartridge and remove ALL the tape that protects it thats why its leaking
Mar 17, 2011 | Dell 3010cn Laser Printer
Hp cm2330 remove shipping lock
HP Color LaserJet CM 1312 Series MFP customers may experience a failure during initial printer startup. After installing the print cartridges and powering on the printer they may receive an error condition or error message on the printer’s display. The printer’s orange Attention LED will flash and a Remove shipping lock from XX cartridge message will appear on the printer’s display; where XX represents the black, cyan, magenta or yellow print cartridge or any combination.
SOLUTION: First, verify the print cartridge shipping locks (orange ring attached to the toner as shown below) have been removed from the print cartridge(s) in question. Second, verify the front and back doors of the printer are properly closed. If the shipping lock has been removed, all doors are closed, and the Remove shipping lock from XX cartridge error remains a unit exchange is the recommended solution.
Contact Hewlett-Packard Customer Support. Refer to your warranty/ support documentation for the number to call in your area. Refer to this document’s number (c01677135) with your customer service representative.
Hp tech support phone for this model # : 1 800 334 51 44
Or you can take the printer to an HP Authorized Repair Center, heres a link will help you find one near your location:
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
You can contact me directly on:
eliteprintersolutions@gmail.com
Jul 15, 2010 | HP Laserjet CM2320nf All-In-One Color...
Paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Mar 01, 2010 | HP Laserjet CM 1312NFI Color Printer
How do i install a toner chip on my hp Cp2025
They're called "toner cartridges."
- See the instructions that came with your printer, but here are the basics
The HP Color LaserJet CP2550 has 4 toner cartridges, one black and three color. Only one cartridge can be changed at a time. They are on a rotating carousel. So you first press the Rotate Carousel button until the cartridge you want to change is selected, then turn off the printer, open the top, pull out the old cartridge, put in the new (being sure it's the correct color), then pull off the tab that keeps the toner from leaking.
HP's toner cart installation instructions are at
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00242813/c00242813.pdf
and the general manual is at
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00242826/c00242826.pdf
toner cart stuff starts on page 12.
If your computer will not open these pages, you need the free Adobe Reader, get it from
http://get.adobe.com/reader/
(I suggest you click to uncheck the "Free McAfee Security Scan Plus.")
Nov 07, 2009 | HP Color LaserJet 2550n printer + HP Color...
9,821 people viewed this question
k24674
