My father has an older model two and a half ton goodman gas package unit. it has had two boards put in it, the problem is that the unit will go through a heat cycle and the combustion motor and the circulating fans will not cut off. The loop from the board through the limits is fine. The new boards did not fix it, all components check out.
  • Mark Egan May 11, 2010
    Does the thermostat ever satisfy that the space is heated?
    If not, then the fans will not go off and you need to look for a different problem, like a dirty A coil or something.
    If the thermostat does satisfy, first thing is to know if the thermostat fan switch is set to ON or Auto. On, the blower runs all the time regardless (but does not explain combustion air motor.).
    Reply what you see and I'll help you more.
    Problem Solver:
  • 6 Answers
The fan induction motor produces a vacuum, check of orofice on motor is plugged by pulling hose off switch end and putting in mouth while running and sucking, this will make a whining sound immediately if no restriction. the fans are controlled through the board by vac., swich, limit sitches, and timers in the board itself. maybe a bad ground on flame sensor.
Posted on Feb 16, 2009
I just installed this unit and can not get the blower to run
Seriously depends on what unit you have. Model # & serial #? You can "jump" R to G at the unit. If its a standard Goodman AHU there may be a terminal block or just some wires that were factory installed outside of the unit. R to G will send 24v to the blower relay, sequencer or board (depending on model) energizing the relay and then returning to common. If you have tried that you should ensure you have proper line voltage 220-240vac. at the service breakers on the AHU.
May 18, 2015 | Goodman Manufacturing Goodman GPH1330M41...
Where is fuse for 5 ton goodman package unit heat pump
Im assuming you mean the low voltage fuse? In that case its located on the circuit board inside the electrical panel on the unit. If looking for the high voltage fuse (breaker) you should have a disconnect outside protected by a breaker inside at the electric service panel (breaker box).
Travis--
Mar 25, 2014 | Goodman Heating & Cooling
Goodman package unit heat strips will not turn on
Put meter probes at in put terminal of the element if you read 220volts that mean your relay is good. if you got it there use amp meter on one leg of that element. You should read some amp draw there but if there is no amp draw it mean the element broke.
Nov 29, 2013 | Goodman Manufacturing Goodman GPH1530M41...
How to wire high voltage goodman straight a/c package gpc1324 unit with 8kw heat kit
do any one have a old package unit is a goodman i want to see were heater on that package uint or take picture of that unit so i can see where the wire go at the heat
Aug 17, 2012 | Goodman Heating & Cooling
I'm trying find out if my old goodman unit was a
Hello WESLEY The unit mod# is 3 ton.If the inside part has an 048 number means together it produces 3.5 ton.If inside is 036 it is 3 ton together.If it is a split.If it is a package it is 3 ton.
Aug 02, 2010 | Goodman Heating & Cooling
Keepe shutting down the heat.
Mark is right 5 tons is way too big and you are probably icing up. Even here in Az we size units to no less than 500 sq. ft. per ton and more like 700 sq. ft. per ton. What is the make and model number of your unit? I'm a Goodman Authorized Contractor so I should have most info on hand.
Feb 13, 2009 | Goodman Heating & Cooling
Older Goodman gas package unit combustion and circulating fans
There is a limit switch tripped somewhere. it is either the main limit in the firewall orthe limit switch on the small fan (inducer) that is tripped some of these are manual reset try pushing the button in and see if that stops it.
Feb 03, 2009 | Goodman CLQ36AR49 Air Conditioner
Brand new goodman 2 and half ton package unit runing all the time
Sounds like the Thermostat or board is wired incorrectly(being new)
have the installer come back and rewire it.
Please rate this solution.
Jan 16, 2009 | Goodman CKL49AR49 Air Conditioner
Gas Package Unit Keeps Running with all T- stat wires unpluged at the unit?
does that unit run heating or just the fan run? if just the fan you may have a bad fan thermostat
Oct 21, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
