Question about Olympus Camedia C-450 Zoom Digital Camera
Card set up
Everytime i open my olympus camera it always viewed CARD SET UP and when i select FORMAT it says CARD ERROR. and camera is not working for shooting, there are just some instances that i can shoot
    President:
  • 919 Answers
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb or 2gb cards are not compatible. The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
Posted on Jan 29, 2009
SOURCE:
Everytime i turn the camera on it tells me i have a card error, i bought a new card and it is still telling me i have a card error? what can i do to solve this???
try going in to the settings menu and selecting the format option. New cards are generally not formatted and using the cameras software formats the card to be used in the camera. also note: I have found olympus or kingston cards to have compatability issuses when used with fuji cameras so I stick to fuji cards as a rule.
Aug 22, 2012 | Fuji FinePix S8000fd Digital Camera
MY OLYPUS E-500 SAYS CARD ERROE WHEN I TURN ON MY
Did you try to format the card using the camera's software or your computer?
May 20, 2010 | Olympus EVOLT E-500 Digital Camera
Clean or format card error on Olympus XD card
There are most likely some "corrupted" images on your xD card. Very often a card reader "writes" data to the card while transferring or copying images into the computer. When you re-insert the card back into the camera, it doesn't recognize the new data (because it didn't create it), and gives the error, usually requiring a complete formatting be performed. There are also problems if you use a reader to rotate images, then re-install the card in the camera. The best way to accomplish what you were doing is to transfer the images into a folder on your computer, as the camera shot them (don't rotate them first). That way, you haven't altered any data on the card. For now, however, I suggest you format the card in the camera, so you can start with a "clean slate". Good luck.
May 02, 2009 | Olympus Stylus 850SW Digital Camera
My Olympus FE-170 won't upload pictures.
Format your camera's internal memory and also format any memory cards you insert.
Use a program called Recover4All to see exactly what is in your camera's internal memory.
Then insert a memory formatted memory card and take some pictures. see if they will upload.
Sep 20, 2008 | Olympus FE-170 Digital Camera
Olympus FE-210 Camera Problem
Format the card, this error idicates that some required data is missing from the card .
Feb 26, 2008 | Olympus Camedia C-350 Digital Camera
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
Card error
YOu might have a bent pin in the camera memory slot. Try the SM card (has finger contacts instead of pins), not the CF (prone to bend pins due to design) if it is a dual format camera.
Oct 17, 2007 | Olympus Camedia C-4000 Zoom Digital Camera
Olympus mji 700
It has to go back the Olympus for replacement or to seller if less than one year.
Sep 02, 2007 | Olympus MJU 400 Digital Camera
Olympus Camedia C-450 Zoom Digital Camera Logo
204 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
