Question about Viking DMOC205SS Microwave Oven
Viking microwave has digital lights but will not turn on to cook?
Clock works and I can enter a cook time but when I press start nothing happens. when I open the door the light does come on so there is power.....help
  • 1 more comment
  • bgurley Jan 29, 2009
    We have the exact same problem.  To answer the questions:
    1) quiter than usual
    2) seems like the computer and digital screen are working (for instance, the times counts down)
    3) ...BUT it no longer appears to be cooking
    4) light is on, turntable is NOT on
    5) does not get hot any more...
    6) model number: VM0S200
  • William Miller
    William Miller May 11, 2010
    So the Start pad does not beep?
    What is your model number?
  • William Miller
    Sorry but your subject line was too long and got cut off.
    Please reply back with your model number and symptoms.
    When you hit Start to
    cook, do the inside light and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
  • 36 Answers
Hi the problem will be with the touch panel membrane or the controller. if yoiu can hear a click when the start button is pressed then the touch panel is OK asnd you should look at the controller which can be replaced as a unit or if you are up to it it's probably the main cook relay that has failed.
Posted on Jan 04, 2010
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
The problem is that when I press the 'Start' button, nothing happens. The clock is working, the fan is working, but I cannot cook anything even after I have entered the time and the power level
If when you press the start button the turntable starts but no heat then magnetron is faulty otherwise if nothing happens then the touchpad itself is faulty.
Oct 10, 2013 | Samsung 1.8 Cu. Ft. Over-the-Range...
R-402JW-T won't cook
From your description you have a bad door switch, there are usually a few of them located inside the microwave under the keypad control board that will need a digital meter to trouble shoot.
Jun 28, 2012 | Sharp Microwave Ovens
Kenmore Elite Microwave has power but will not start?
switch if off completelty for approx 5 mins and then power it back on
Oct 26, 2011 | Microwave Ovens
My new Haier microwave isn't working! I just plugged it in for the first time, and set the clock on it. Then I tried to turn it on. No matter what cook time I enter, and then press start/30 sec., nothing...
When it times down but doesnt heat it is typically a problem with the door switches, especially one you just bought, may have been from shipping . A switch or connection may have been disodged when being shipped to you. Most machines have something like 4-5 wswitches, If 1 doesnt report right it will stiop the unit from running. But since some of them are closed it will accept the programing and try to operate. So a lot of times you get fan running and tray turning but no power to the secondary circuits. You will need to find out who does warranty for them or return it where you bought it as a defective unit.
Aug 14, 2017 | Haier Microwave Microwave Oven
Enter time & press Start the timer begins but no heat
Sounds like you have a bad door switch. make sure each button on the top of the switches snaps back up after it is puched down. Also, look at the wires where they push onto the switches. if any of the plastic insulators look brown you have a bad connection there and will need to replace the switch and the terminals going to it.
Sep 11, 2009 | Microwave Ovens
Sharp R1505 Microwave
when you press for the time you want does it come up on yhe display?? if not clean the circuit board with wd40, & retry dont go two fast when operating as this can lead to the machine not to respond. also check the pad give it a clean and a good dry,
Apr 07, 2009 | Jenn-Air JMV8208A Microwave Oven
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
May 11, 2008 | Microwave Ovens
Viking DMOC205SS Microwave Oven Logo
338 people viewed this question
Top Viking Microwave Ovens Experts
William Miller
William Miller
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Viking Microwave Oven Expert? Answer questions, earn points and help others
