Remote code for a sylvania LC370SS9
What is the remote code for a sylvania LC370SS9 to work with dish networks universal remote
  • w9918 Jan 29, 2009
    If I have solved my problem You want free advise but if I haven't solved my problem then you want too charge me. WHAT A NICE SCAM YOU HAVE GOING ,i WILL MAKE SURE AND PASS THE WORD.
5 Suggested Answers
  • 520 Answers
SOURCE: Dish Network universal remote
Here are the codes for Orion tv's for Dish Network remotes.
Orion: 694, 720, 729, 220, 221, 623, 695, 227, 754, 721.
Posted on Nov 14, 2008
SpotBert
  • 231 Answers
SOURCE: Need RCR450 Code for Sylvania LC370SS9
Here's the manual =>
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
Sylvania TV codes are 1004, 1006, 1008, 1019, 1062, 1068, 1069, 1075, 1076, 1088, 1130, 1132, 1134, 1183, 1189, 1251 listed in back of the manual.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Posted on Jan 16, 2009
SOURCE: Sylvania lc370ss9 remote problem, comcast
you have to turn off the power save setting
Posted on Apr 17, 2009
SOURCE: universal rca remote rcr312w codes for sylvania tv
the code for sylvania rcr312w is 1192
Posted on Apr 20, 2009
I need a remote code for my dish network VIP722k DVR with my sony RMVZ320 remote
Check with DiSH for a possibly unpublished code. You may find that only the DiSH remote will work.
Jan 01, 2014 | DISH Network IR Remote Control
I need a code to operate a Vizio Blu-ray player, VBR231, with Dish Network remote control. Thanks! ctelschow@msn.com
HERE ARE A FEW SUGGESTIONS TO LOCATE A SUITABLE CODE FOR YOUR
VIZIO BLU-RAY PLAYER, MODEL VBR231
  1. HITATCHI CODES ~ VIZIO CODES
    WHICH MEANS YOU SHOULD TRY HITACHI BLU-RAY PLAYER CODE(S) LISTED IN THE DISH NET RC MANUAL.
  2. FROM DISHSUPPORT.COM FORUM:
    Scott Greczkowski
    DISHSUPPORT STAFF
    hances are the 5.3 remote will not control that Blu-ray player. What will work however is a DISH Network 21.0 remote which not only has a better IR code database, but also is an IR learning remote. This means if the code is not in the remotes database you can teach it to learn all the functions of your Vizio Remote.The DISH 21.0 remote will also work fine with your 622/722.If you can't find a 21.0 remote then please PM me and I can tell you where you can order one. They may also be available from DISH Network directly.
*Configuring your devices with a "UNIVERSAL" Remote can sometimes be a stressful and frustrating experience. But it doesn't hafta be!*
Here are a few general
GUIDELINES TO UNIVERSAL REMOTE CODE SUCCESS
  • READ THE ENTIRE INSTRUCTION MANUAL THAT IS INCLUDED WITH YOUR UNIVERSAL REMOTE (OR DOWNLOAD ONE FROM THE VENDOR'S WEBSITE)
  • USE THE REMOTES "AUTO CODE SEARCH" FEATURE TO FIND A MATCH TO YOUR DEVICE (IF A DEVICE HAS ONLY PARTIAL FUNCTIONALITY e.g. CHANNEL +/- WORKS, BUT VOLUME +/- DOES NOT= CODE IS NOT THE BEST MATCH FOR YOUR DEVICE)
  • PRACTICE PROGRAMMING (AN)OTHER DEVICE(S) IN YOUR HOME TO MASTER THE PROCESS OF PROGRAMMING CODES WITH THEIR MATCHING DEVICES USING YOUR UNIVERSAL REMOTE CONTROL. TRUST ME, IT BUILDS CONFIDENCE, ASSURES THAT THE RIGHT PROCEDURE IS BEING FOLLOWED IN ORDER TO PROGRAM THE REMOTE, AND PROMOTES EXPLORATION OF THE "UNIVERSAL" ASPECT OF THE CONTROLLER.
Apr 02, 2011 | DISH Network Televison & Video
Remote codes
try these, They are Sylvania manufactors codes.
0054, 0030, 0020, 0096
Hope this helps you out
Cheers Little Dish Fitter
Sep 21, 2009 | Philips Magnavox Learning Universal Remote
I am trying to program a universal remote for the Sylvania 6427tv
try these four codes
hope this helps
Cheers
Little Dish Fitter
Sep 01, 2009 | Televison & Video
I have a dish network remote control that I am trying to use to get to my video 1 or video 2 channels on my Sylvania 6420FF tv. The Sylvania remote is dead to the world and I need the Dish remote to get to...
You will need to by a universal remote in most circumstances as the Dish remote may not cycle through the inputs on your tv. You can try the recovery button on the remote it will have a small R on it. Press it many times to se if it it set to cycle through the inputs. Thanks for using Fix Ya.
Aug 01, 2009 | DISH Network 118216 Remote Control
Mar 01, 2009 | RCA RCR450 Remote Control
Dec 28, 2008 | RCA RCR450 Remote Control
DISH network universal remote
http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/remotes/TechRemo2wayCode.shtml
Here is a list of remote codes that dish has for your remote.
Jun 26, 2008 | Universal Remote Control Dish Network...
Programing one for all remote for a sysvnia model tv ld320ss8
I also own a Sylvania LD320SS8 HDTV. My solution to the
problem of remote codes that won't work is to junk the
Sylvania, and buy a reputable brand TV such as an LG
HDTV which will work nicely with DirecTV or Dish network
remotes.
Feb 28, 2008 | Televison & Video
Codes for sylvania tv
I purchased a sylvanis lcd tv and it won't work with my comcast cable remote...I can't turn it on or off with it or turn up or down the volume. i've called my cable company 3 times and they can't seem to help me. Can you help?
Feb 10, 2008 | Zenith ZEN450 Remote Control
Televison & Video Logo
160 people viewed this question
Top Televison & Video Experts
Electro Med Services...
