Kelvinator ksr27g won't restart
I think we might have had power surge or similar as the fuse tripped i have turnd it back on but the air con still wont start.... it is 42c deg ..help please !!!!!!!!
  • duncs5 Jan 29, 2009
    hi idare ya, thanks for helping. where do i find the capacitor?
    i have turned the unit on and off with no success.
    the remote works but the main unit wont turn on at all.
  • 95 Answers
There is a capacitor that blows from surges it will have an burnt smell to to and may show discoloration. careful it may have a charge in it. does the moter cycle on and off? If so it could be blown. Another thing that helps is if the motor has been trying to start repeatedly it will overheat you will need to turn it off and allow to cool down before restarting.
Posted on Jan 29, 2009
  • idare_ya Jan 29, 2009
    It will be located on the compressor or very close to it. WARNING capasitors store electricity it should look like a can. See if you can find schematics.
Eu6500is generator trips to red unload when ac is on
Air conditioner compressors require a greater amount of electricity (measured in both volts and amps, but the amps are what is causing the overload). You will need a larger generator to run your AC. You might be able to run a smaller AC unit, but always check the Amps required and compare that to the Amps the circuit breaker on the generator is rated for.
May 30, 2016 | Honda EU6500iS Inverter Generator
I just moved into a new home and the air cons are kelvinator r51k bgce and it won't turn on when i use the remote and the batteries are working?
pull up the front cover the grill looking piece , not the air out louvers , there maybe a little button , push that in if air con starts up , then you remote sensor may be faulty or the remote itself .
Mar 28, 2014 | Heating & Cooling
Jbl eon 518s power trip on stabilizer/transformer
hell no thats a fire hazard.. I am thinking that the surge is more that that unit can handle..surge is the extra power needed to start up an electrical piece of equipment..surge can easily double the amount of power required for startup..may need a new powerstrip with a much heavier rating..
Jan 12, 2014 | JBL EON 518S Subwoofer Speaker
Air con dead
Larger split system air con gets power from the external unit while smaller air con gets power from the internal unit. Can you find any power switch or power socket/plug around the external or internal units?
Nov 19, 2013 | Cell Phones
Kelvinator ksr27g con manual
see the led bulb of the remote control by using a camera then switch on the remote if it blink the remote is good but if not its bad. dont forget to put an battery on it. then test the ac unit manually, if the unit start replaced your remote control.
May 30, 2013 | LG LSC121PMA Split System Air Conditioner
Need to change from cooling to heating for a Kelvinator KSR27G split sys air con. Have tried ourselves using the remote, but we feel it is not operating correctly. No manual came with it when we purchased...
The cooling symbol on the remote is generally an "icicle" , the heating is a symbol of a blazing sun. Make sure you have selected the right mode. Also check the filters... if they are dirty, you wont get decent heating from any air con.. cheers,
BTW, I believe that electrolux have a site you can download instruction books.
Jul 14, 2011 | Heating & Cooling
I have a 1 1/2 year old Panasonic TC-P42U1 plasma tv. While watching a show, it suddenly shut off and won't come back on. What do you think caused this and how can i fix it? Thanks.
Try unplugging it completely for 30 seconds to 1 minute. Plug it back in. If it still won't come on, it's likely taken a power surge and popped a fuse or power supply, which means a trip to the service center.
Jun 18, 2011 | Panasonic TC-P42U1 42 in. Plasma HDTV
I've got an error 1 message on my Kelvinator air
Here is a Toll free number to Kelvinator. Good Luck!
Technical Support Center - U.S.A. 1 (866) 738-1641
Monday - Friday
8:00 am - 6:00 pm EST
Nov 13, 2009 | Heating & Cooling
Power led flashing on air conditioner
This generally indicates a fault with the unit. Have you tried cleaning the air filters inside the indoor unit. This may help. Otherwise call Kelvinator or LG as they have similar unit and ask for their help and if it can't be rectified call for service.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Heating & Cooling
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
Heating & Cooling Logo
291 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
