When i press 8&c it is write please wait then call for service, and all part of paper jam, paper tray and toner the light is bim
SOURCE: e studio 16
More than likely you have bad feed tires in the tray you're pulling from or if the drum unit is stuck there probably is paper jammed up in the unit. Replace you feed tires and check your drum separation claws when you are able to get the drum unit out.
SOURCE: "Broken Registration"
U need to press "STOP" to return to idle state.
If this Error Message is repeatedly displayed, machine programming
has become corrupted.The machine must be re-initialized.
Pressing *13 and ON the machine, it will re-initialized the fax.
SOURCE: toshiba e-studio 550 call for service F10
Do the following.
Hold down 0+8 and turn the copier on.
Type in 690 then hit start.
Make sure there is the number 2 displayed.
Press enter on the touch screen.
Reboot the machine when told to.
SOURCE: Toshiba estudio 160 Password
Code 08- 263 does not work with the e160
And I cannot find anywhere in the service manual where it specifies how to read it...
08-252 "0" for clearing the message.
08-251 for setting the value of PM message
