Question about Garmin n?vi 260W GPS
Display reads no detailed maps found that support routing.
And, the nuvi cannot be used without them. Unit is about 4 months old and always worked fine. Brought in inside tonight to input address of trip and all these dots appeared on screen with words touch dot next to them I did this and it finally said your unit is calibrated? Now I screen freezes pon the message screen and never even get to screen that says where to and view map?
  • scadams Mar 16, 2009
    Pretty much the same as above. Have had unit for just over 5 months and has been workin fine until yesterday. Calibration screen came up when unit powered on then got same message about no detailed maps. Tried using the reset button then holding power button to left for 8 seconds, unit reset both times but got same message each time.
  • Garmin Expert
  • 343 Answers
Try a Master Reset:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 2xx series device:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings. But who cares if you have problems, right?
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Posted on Jan 28, 2010
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
Everything went dead within 2 hours. The only thing the unit will do is display the following message. - - - - No detailed maps found that support routing. The nuvi cannot be used without them. - - - - -
I would check your map to see if it has a check mark in it.....
Tools.... Settings....Maps..... on bottom of screen Map Info.....make sure a check is in City Navigator North American NT
Oct 30, 2010 | Garmin nuvi 200W GPS Receiver
Was working fine and suddenly deided to lose maps. message on screen says "no detailed maps found that support routing. The nuvi cannot be used without them." What happened and how do I GET THEM BACK. ...
Call up Garmin and have them walk you threw a trouble shooting procedure. It sounds like your unit has erased itself by no fault of yours. Garmin will replace it once you get ahold of them. There is not anything that we can do without thier support.
Nov 25, 2009 | Garmin nuvi 205 GPS Receiver
Garmin Nuvi ~ No detailed maps found that support routing.
Please see this link for more inforamtion on this problem. I can help you resolve the issue. Your map unlock code is either corrupted or missing.
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Jul 11, 2009 | Garmin nuvi® 200 Car GPS Receiver
No detailed maps found to support routing
Have you tried updating the unit at Garmin's Website?
Let me know if you need help, I can get you the right web-link if needed.
Benjamin
Feb 28, 2009 | Garmin nuvi 255W GPS Receiver
Garmin nuvi says, "no detailed maps found to support routing."
I am very sorry to hear that you are having problems with the unit. You
may need to switch the unit on and press and hold the centre of the
screen until the message ?No detailed maps? message disappears.
If your map detail is missing, then the map information may have been
disabled. To check to see if the mapping has been disabled, follow the
steps below:
From the Where to? and View Map page, touch the Spanner icon, settings
(Tools).
Touch Map.
Touch Map Info.
The unit should display the name of the map that is loaded to the unit.
The box in front of the map name should have a tick in it. If it does
not, touch the box to place a tick in it.
Then please test by searching for an address.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
GPS does not have maps
I had the same problum , it showd the car but no roads . My maps where on the sd card , dont know how it got there !!!! when i put it back in it worked ok
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Garmin n?vi 260W GPS Logo
127 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
