Question about Kenmore 18 in. 14432 / 14439 Built-in Dishwasher
Need to dissolve hard soap
My dishwasher is clogged with HARD liquid soap at the bottom of it and the soap is rock hard, so it won't run. How can I disolve the soap?
  • 51 Answers
The internals of a dishwasher are stainless steel and plastic and for these sort of problems a diluted solution oh hydrocloric acid can do the trick......just wear gloves!!!
Posted on Jul 26, 2007
Our dishwasher is not dissolving the soap. Has anyone else had this issue and does anyone know how to fix this problem?
Try using a liquid dishwasher detergent.
Also, if you are using dry detergent (that is not pre-measured in pods, etc.), you may be overfilling the detergent dispenser. When the dry detergent gets wet, it swells and causes the detergent dispenser door to stick.
Apr 13, 2016 | Frigidaire Dishwashers
Kenmore elite dishwasher
Your best cleaning option would be to put a tablespoon of citric acid powder in the machine and run it on hot normal load all the way through. The citric acid dissolves much of the gunk that builds up in dishwashers without damagin any of it's components. You can get citric acid powder at your local Target or CVS (Walmart or Home Depot in Canada).
Another thing to think of... if you are using the dishwasher packets, you will have buildup in your machine as the packets are slow to dissolve fully and can cause plug-ups in certain conditions. Using the hot cycle is really the only way to use them effectively. Liquid soap is a much better alternative.
Nov 29, 2017 | Dishwashers
I have a kitchenaid dishwasher that doesn't dissolve even liquid soap. At the end of the cycle there is hard compacted soap residue that ends up blocking the holes where the water shoots out and there are...
Try getting some calcium, lime and rust remover. Follow the instructions on the bottle and run the dishwasher empty using only the CLR. Check your incoming water lines for calcium or lime build up.
Sep 17, 2013 | Dishwashers
Dishwasher does not dissolve soap
If you have hard water, use only a little bit of soap. And you will probably need to add a rinse agent too. The government recently outlawed phosphate in detergent - now most detergents don't clean very well and don't dissolve either. This map shows the hard water regions in USA:
http://www.citriclean.net/why-citriclean/
Mar 16, 2013 | Dishwashers
The soap dispenser opens & the soap tablet (power ball) drops to the bottom but doesn't dissolve
1. Water temp is wrong should be 140-145
2. spray arms clogged with food
3. water valve is not letter the correct amount of water in
after it fill's check to see water amount in bottom , dose it sound like it is starving for water ? it would sound like it was surging
Dec 01, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher soap is not dissolving.
Try emptying the dishwasher and putting a few tablespoons of vegatable oil in the bottom. Run the cycle without soap and no dishs. Often dish soap (palmolive) builds up and creates soap suds that won't go away during a normal cycle. The oil binds with the soap residue to get rid of it. It worked for my Kenmore. I know do it every few months. Good Luck!!!
Thanks
Jun 22, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
The soap packet doesn't dissolve, it remains intact at the bottom of the machine at the end of the cycle.
don,t use those packets stay with powder or liquid dishwasher soap. the packets need a lot of heat to dissolve,.
May 29, 2009 | GE Nautilus 24" Built-in Dishwasher
Soap hardens in the dispenser and dishes don't come clean
Either your dishwasher is not getting the water hot enough to dissolve the powder, or you need to switch brands. Try a liquid/gel type of dishwasher detergent.
Try stopping the washer a few minutes after you start a wash cycle. Open the door -- if there is a lot of steam coming out at you, it's not the water temperature. If there is no steam, your dishwasher is not getting hot water and/or the heating coil is not working.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Soap is in the dispenser after dishwasher has been run
You need to clean your particle screen under the heating element. It is found at the bottom center of the washer under the heating coil. It is usually a plastic mesh screen and sometimes are removable. This needs to be cleaned really good about every 2 months. This will stop the problem with the suds. Good Luck This Should Help!
By the way I see that you soap won't dissolve this is not because of water temperature it is that the jets in the washer arm are clogged. You need to clean these one by one with a small cleaning device and brush. When these clog the jets of water don't come out with any force they just trickle. Clean the jets(on the arm that spins at the top and bottom of the washer and your screen and it will be like having a brand new washer.
Nov 23, 2008 | Maytag 24 in. DWU9202 Built-in Dishwasher
Soap does not desolve
check that the spray arms are turning and that the holes in them are not clogged, if you line them up pointing towards the front let the machine fill then as it starts to wash open the door and you should see the arms slowing down, if they are okay then check the water level which should just lap the filter at the bottom
Jan 07, 2008 | Jenn-Air JDB6510 Built-in Dishwasher
Kenmore 18 in. 14432 / 14439 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
