When turning on my computer I get a black screen saying enter set up and something about invalid system disk and it ask me to replace disk and press any key. What could the issue possible be? I would like for someone to get back to me as soon as possible. I thank you in advance for your time and cooperation in this matter.
  • Joshua Hansen May 11, 2010
    Make sure you have no disks in any of the drives (3.5 floppy, CD-ROM, etc).
    If you don't have any disks in any of your drives, then you have got a hard drive problem. Go into the "setup" it is referring to and verify it can even see your hard disk drive.
  • 22 Answers
I had rhis problem befor i needed to reinstal my computer hop this wil help
Posted on Jan 29, 2009
Once powered on it goes to black screen and says - INVALID SYSTEM DISC,replace the disc, and then press any key.
Are you sure the BIOS is set to boot from hard disk?
It looks like it is trying to boot from network (PXE) and then from floppy disk.
Jan 04, 2014 | Computers & Internet
Tip
How to reformat a window xp
first nsert the Windows XP disk, and turn off your computer...Turn on your computer...A screen will come up during the boot and tell you to press any key to boot from CD, (if not you will need to change the start up sequence in the BIOS). Press any key you like....Second, you are asked which file system to use, the FAT Filesystem or NTFS Filesystem. NTFS Filesystem is the newer and faster one, so use that. FAT would also limit you to small hard disks..It might take a while. Once everything is loaded, there will be a few options on the screen. The one you want says 'To set up Windows XP, press enter.' So select it and press enter.It might take a while. Once everything is loaded, there will be a few options on the screen. The one you want says 'To set up Windows XP, press enter.' So select it and press enter.Alternatively, if you just want to format a secondary hard drive you can go to 'My Computer', right click on the drive and press format and follow the instructions accordingly.
on Jul 25, 2010 | Computers & Internet
Toshiba portege 2000 windows xp invalid system disk.
When booting, try going to the Boot Menu by pressing F12 when you see the Toshiba logo so you can select your hard drive as your boot device. After doing so, if you still get an "Invalid System Disc" error, then your hard drive may be shot.
Jan 04, 2014 | Toshiba Tecra 510CDT (P000224080)...
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
Wont boot up,black screen.message on screen says,invalid partitio
When you power up your computer, the system examines the master partition table to determine what volume to use to boot up the operating system, and detected invalid information within it. This is caused by an incorrect or missing active partition.
To resolve this issue, consider the following steps:
  • Boot up the computer with a Microsoft Windows 98 boot up disk or Windows XP recovery console. Select the correct bootup device before you do that.
  • At the DOS command prompt, type in: fdisk
  • Question - Do you wish to enlarge large disk support (Y/N) ?
  • Enter: Y
  • Now to check for active partition, enter: 2
  • Look under the Status column. The active partition is usually assigned to the drive which contains your operating system.
  • If there's no active partition set, enter the number of the partition to make active
This must solve your problem.
Apr 15, 2010 | HP Compaq Presario 2200 Notebook
I turn on my compaq and the first thing come on screen is CPU=AMD-K6(tm)/300 00000640K SYSTEM RAM PASSED 00064512K EXTENDED RAM PASSED 0512K CACHE SRAM MOUSE INITIALIZED FIXED DISK 0:FUJITSU...
above 06 lines are related with system information, Go to the BIOS check the startup sequence, if everything is ok save and exit from BIOS.
Apr 01, 2010 | Computers & Internet
No operating system found
If the error message says "No operating system found" it is most likely a faulty disk controller or a faulty hard disk.
Reseat the hard disk, if this doesn't work you need to test the hard disk another way. Remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If this computer sees this as an external hard drive and you can open the folders and files then the hard disk is OK and the fault is the disk controller on the the 4115c laptop.
If the hard disk is not detected then the hard disk is faulty. You need to install a new hard disk, install Windows and the laptop's device drivers and programs to get a working laptop again.
Sep 11, 2009 | Computers & Internet
Dell 6100 laptop blank screen
Boot into the one that says, "Safe Mode with Command Prompt"
Once it's done it will ask for an admin password (sometimes) if it does just press the enter key, unless you set the Administrator password to something else.
Once your past that.
Type:
chkdsk /r
a message will pop up (sometimes) saying something about the disk being locked, blah, blah, blah.
Just press the Y key, then enter.
Restart the computer.
Let it do it's thing ( disk check will appear)
Let me know if this solves your problem.
Feb 28, 2009 | Dell Inspiron 6000 Notebook
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
Error message
hi have you tried switching computer off then back on if this dont solve problem then you need to when you switch computer on it will say press f 1 or f 3 or similar key to enter setup screen once in the setup option you will need to change the setting for startup it will probably say a:/ then c;/ you need to change this so that your c:/ drive is first once you have done this save settings then when you switch computer on it will boot up from c:/ drive and wont ask for disk.
Or on the screen that its on try pressing esc key and see if this will let you write anything as it sounds like you are in dos mode if so type c:/ then press enter then type run this should load up then as normal if dont accept this command try type exit or win if neither work type c:/ press enter screen should say c:/ type win or windows press enter the type run again let me know how you get on ok
Dec 04, 2007 | HP Pavilion a420n PC Desktop
Computers & Internet Logo
David Payne
David Payne
