Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Replacing refrigerator door arm
I ordered replacement arms for my Kitchen Aid Superba side by side. I can not figure out how to get the frame off and would love to know how to exchange them out. The old ones have hard water stains which got worse when I used the wrong kind of cleaner.
  • 410 Answers
On the bottom of the ice dispenser front cover is 2 slots insert a small screw driver into these slots and carefully pry the cover off (be careful not to scratch your door) one the cover is off there will most likely be a wiring harness that you can unplug and put cover out of your way. next you will need to move the white bracket out of your way there is either 2 thumb latches or 2 screws that seure it. it will not come all the way out so you may need someone to hold it out of the way for you. in the center of both of your levers you will see 1 screw with a cardboard spacer and brass spring BE CAREFUL NOT TO LOOSE THESE! remover screw spacer and spring afte that you should be able to work the levers right on out. the ice lever is a little tricky trying to get it around the ice door but it will come out. btw just use white vinegar to clean hard water stains in the future. thx peyton... also dont forget to unplug the refrig.
Posted on Jan 29, 2009
  • peyton thompson
    peyton thompson Jan 30, 2009
    Hi I was wondering if you had any problems replacing your levers. if you have any questions just leave me a message. Thanx Peyton
Kitchenaid superba ksrg25fkwh01 wire harness
Called Kitchen aid and protested, frig was 4 years old at the time. door was almost $1200 to replace. Kitchen aid paid for new door and installation
Sep 19, 2012 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker Arm of Kitchen Aid Superba 36
There is trick to putting the ice bale arm back on unless the water cup where the water comes into freezer has the round opening broken that holds the bale arm Click Here=> 628356 Water Fill Cup
Also the video clip from Parts Select will show you the way to do this way of reinstalling the bale arm. If movie does load below then click HERE Telling you how in words would not be as simple as the instructions given in the movie. Thumps up to Parts Select on that tutorial! I will be here if you have questions and please rate if helpful Thank You Sea Breeze
Oct 18, 2011 | KitchenAid Superba Architect KSCS25INSS...
Can I replace the freezer door seal on a kitchen aid myself?
some door gaskets snap into a track and others are held on to by screws in a metal frame. you can pull the back of the gasket apart to see which you have.
are you sure that the gasket is bad? you can do the dollar bill test by placing a dollar bill between the gasket and door frame and shutting the door. if the dollar bill fits snugly and is not loose the gasket is good. However you may be able to look at your gasket and see that it is torn or warped and not sealing good.
replacing the door gasket can be a little tricky but with a little patience and some very hot water to soak the new gasket in to make it easier to work with, you should be ok.
keep the bottom of your refrigerator and freezer frames clean (this is where everything spills and gets sticky) to keep the gasket from sticking to the frame and tearing up over time.
Jul 24, 2010 | KitchenAid Superba Architect KSCS25INSS...
Problem with KitchenAid Superba KSRG25FK Side/Side Refrigerator
I found you looking for keep en mind kitchen aid is made by whirlpool good luck :)
Jun 12, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Kitchen Aid Superba - door needs adjustment
there is two bolts oin the very front of the unit behind the kickplate the oiu can turn clock wise until there is a slight tile toward the back of the unit so that the cams on the doors will have a little bit of gravity to helop them stay shut.
Mar 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Agitator will not work
kitchen aid is hte same as the whirlpool so if you have directions for that one it will work on your current one,, part number 80040
Oct 23, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid superba door problem
Oct 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Superba Dishwasher filter replacement problem
I dont think that it is made for you 2 move it.
If it isnt dirty then there isnt really no use. But if it is dirty write back and ill try to help you :)
Sep 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
check the holes in the spray arms to see if they are plugged also brand and model number will help
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
