Question about D-Link DPH-50U (0790069289750) Router
Using D-Link DPH-50U with a softphone ie. Xlite,eyeBeam, etc
I have the D-Link DPH-50U working PERFECTLY with Skype and the PSTN.  Now I'm trying to use it with a SIP account, using Xlite as the softphone.  IS THIS POSSIBLE ?  Anyone know how to do it ?
    Scholar:
  • 108 Answers
That phone looks exactly like the one I use from sjlabs.com. I have a SIP account with FWD on mine. The router should have nothing to do with it unless you are behind a corporate router with strict ACLs. The soft phone is software based. Just make sure your STUN server and SIP proxy is set up correctly. The Xlite should provide all the info needed,
Posted on Jan 29, 2009
I have a use d-link 50u ip phone what do i nedd to make work i don't have a manual to install
http://www.dlink.com/products/default.aspx?pid=DPH-50U&tab=3
Click on Support Resources, Pick your country and download a manual or driver, everythings there
Aug 01, 2010 | D-Link DPH-50U IP Phone
I have installed Skype 3.8 and d-link driver 1.01 on Windows xp. I can select the device from the audio setting but receive no dial tone. Please assist!
In your VoIP monitor settings there are two options to make your phone connect to voip. You either have to dail # # or # *. I would try hitting pound twice, but it's kind of tricky because sometimes when the dlink tries to connect it will flip back and forth between voip and pstn. So I recommend holding the phone to your ear and hitting # until you hear that dial tone!
Jul 01, 2010 | D-Link DPH-50U IP Phone
Need to connect my landline to skype
No Skype is DIGITAL all fax machines are ANALOG.
Jul 07, 2009 | Brother MFC 240C All-In-One InkJet Printer
Failed to register! error-code: 408, msg: 'Request Timeout'
Errors / Solutions (Error 408, 401, 503 / Not Connecting / Failed to Register / Audio Problems):
You can try using port 8891 or 80 setting if 5060 port is blocked
Simply change the sip.tpad.com settings in Xlite to
sip.tpad.com:8891
or
sip.tpad.com:80
Use our STUN Settings, simply use the info on this link (stun.fwdnet.net:3478)
http://forum.tpad.com/viewtopic.php?t=617
http://www.youtube.com/watch?v=ugHwkl--zhQ
Use these other Free Softphones with Tpad:
http://forum.tpad.com/viewtopic.php?t=623
http://forum.tpad.com/viewtopic.php?t=864
http://forum.tpad.com/viewtopic.php?t=657
http://forum.tpad.com/viewtopic.php?t=456
May 02, 2009 | Computers & Internet
Using the D-Link skype/pstn switch with a SIP account
please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
Jan 29, 2009 | D-Link DPH-50U (0790069289750) Router
DPH-50U can't be uninstalled or reinstalled correctly
To solve a problem "device not present", you must delete registry key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{55280429-413e-460f-a31a-e19314823119}\0001" and restart service "VService".
Dec 14, 2008 | D-Link DPH-50U IP Phone
DPH-50U default audio
I had the same problem. I just reinstalled the hardware manually through the install new hardware module in XP. Once I did that, Skype "saw" the D-Link adapter.
'I went into "add new hardware" clicked "yer, hardware is already installed" then selected the D-Link device that will be listed. You have to have the driver already installed, then let the OS install the hardware as it always does and then you should see the D-Link driver as one of the choices.
This drove me crazy too. I hope this works for all of you. Good Luck.
Oct 24, 2008 | D-Link DPH-50U IP Phone
How to do voip calls with the regular phone
Did you read the manual?
first you press ##
then you will hear a weird buzz
then you dial 00 and then the phone number including the country code (example in canada.. you will do 00 1 450 419 0000
then you press *
so again,
## (weird buzz) 00 1 450 419 0000 *
and wait few seconds
Nov 15, 2007 | D-Link DPH-50U IP Phone
Open Questions:
Cable Modem and Wireless Gateway in Different room than computer. I have and would like to use the DPH-50U to hook up my regular cordless phone to use Skype and my regular phone service, which is thru my ISP. (My phone is currently also plugged into my cable modem.) The room where the cable modem - a Webstar DPX2213 - is hooked up to the SMC 8014WG Wireless Gateway in is NOT where my main computer is located. Currently I am wireless between the SMC and my main laptop. All works well with that set up. The problem is I can not physically plug the DLink adapter to the modem AND my computer because the modem and wireless gateway are not in the same room as my computer. I have an old IBM laptop and DLink AirPlus DWL-G650 wireless adapter. Could I connect the IBM via ethernet cable to the modem and have the DLink USB phone adapter connected to it then make a wireless connection between the IBM and my main laptop that is in other room? If so would I be able to connect with Skype with my main computer or would I have to use the IBM with that set up? If it is not possible to use the IBM to connect everything in the other room I wouldn't mind having to plug the phone to the DLink adaptor when I want to use it with Skype and then unplug it when done with Skype (and back into the cable modem) if this is the only way to do this given the set up - if would not cause problems. Of course I'd rather be able to use the DLink voip adapter as it was intended. Alternately maybe it is possilbe to just use the IBM to service the phone and skype and leave things as they are with my main laptop. I hope this is clear enough for someone to be able to answer. Thanks!
Feb 28, 2017 | D-Link DPH-50U (0790069289750) Router
D-Link DPH-50U (0790069289750) Router Logo
845 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
