Question about Sony FD Trinitron WEGA KV-20FS120 20" TV
Tv repair i have a sony tv (kv-20fs120). its almost 3 years old. when plugged it in and i push the power button on, the power/standby light blinks 4 times while tv is on with blank/black picture then turn off. what might be the problem?
  • 5 more comments
  • Anonymous Nov 06, 2007
    sony trinitron kv32fs100 power light blinks 5 times
  • Faulkner Feb 14, 2008
    I have a Sony Trinitron Model No. KV36HS510 also. The picture is black and the standby light flashes 7 times. Anyone have a solution?
  • SKIPPY77 Feb 29, 2008
    I HAVE A SONY KV-13FM13
    NO PIC OR SOUND STANDBY BLINKS 4 TIMES
  • jbshomo Apr 01, 2008
    I have the same Sony Trinitron. Picture and all else went blank, now the Standby/Timer light flashes 4 times...then repeats.
    Any thoughts?
  • Anonymous Apr 09, 2008
    the tv torn ot after 30 minutes
  • ColleenMc Apr 13, 2008
    How can something like this happen? I have the same problem with my 37 inch widescreen trinitron, just watched tv 2 hours ago, shut it off. We came back and turned it on, nothing happened just the light blinks a few times and eventually stops. How much should something like this cost to have repaired?
  • robert groth Apr 06, 2009
    I have the same problem on a KV-34HS510. I called repair shop to check price but they cant tell what the SMPSU is. Could it be called something else?
  • Sony Master
  • 12,061 Answers
Undoutably the SMPSU (Switched Mode Power Supply) is faulty.. This will be a shop job... ensure you get a firm "Quote" and explanation B4 allowing it to be fixed.
Posted on Aug 01, 2007
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony Trinitron shut down last night. I
4 times standby light blink shows that tv got problem in vertical deflection section and probably vertical output IC got defective, need to be replaced.
Replacement of parts in circuit board requires soldering work and expertise so call local tv repair shop guy if you are not familiar with soldering work.
Thanks.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
TV won't turn on
The 9 blinks usually mean that the power regulators are shot. This is a relatively simple repair and is a wear and tear item. Expect about $25-$35 in parts plus the local labor rate for the total repair cost. If you want to try and repair it your self, I can look up the part designations and numbers.
Keep me posted.
Dan
Jun 12, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Sony tv kv-36fs120 will not turn on
Use a hair dryer on the back right side of unit. Humidity sensor may be causing the unit to stay off. The hair dryer may also remove dust causing a false humidity detection
Nov 10, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron WEGA KV-20FS120 20" TV Logo
250 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
