Question about Galaxy Radios DX-99V 40-Channels Base CB Radio
CB RADIO TRC 446 WILL NOT RECEIVE
EVERYTHING WORKS BUT WONT RECEIVE USEING A 102 WIP
  • Tom Arsenault
    Tom Arsenault May 11, 2010
    When you say no recieve, do you mean no audio, or no indication of a recieve signal? When you say everything works, exactly what works and what doesn;t work. What have you changed besides antenna?
    I have several years of bench time and I know we can fix this problem.
    Tom
  • 55 Answers
IF YOU CANT RECIEVE THAT IS A VERY GOOD SIGN THAT YOUR SWR MATCH IS OFF....I DONT KNOW IF YOU MATCHED UP YOUR RADIO WITH YOUR ANT.IF NOT YOU CAN BUY A CHEAP SWR METER @ RADIO SHACK...CHECK THAT YOUR COAX CABLE IS OK TRY TO REPLACE THE COAX......GOOD LUCK
Posted on Feb 21, 2009
Trc 446
with this radio,I would probably go and buy another . It will be cheaper than having someone fix it.give more information about what its doing or not doing and maybe some one will give you the help you need but I would buy a better radio.
Sep 03, 2014 | Radio Shack 40 Channel Cb Radio Model...
My trc 446 wont recevie ecept for weather
check your mic connections ,make sure there are no broken wires.
Dec 24, 2013 | Galaxy Radios DX-99V 40-Channels Base CB...
Need mic wiring diagram for trc-446
you may have to order one from radio shack because the wireing diagram is for that radio and mic only . You cannot use another mic on that radio , only the one that comes with it . If you are patient enough and have another mic with the same controls you could wire it up. it has to be ( I think a 6 pin ) ???
Nov 10, 2013 | Radio Shack 40 Channel Cb Radio Model...
Cb radio trc446 rewiring microphone color coding
if you pulled it completely out you may have a problem . Trial and error is all I can tell you.Get a volt meter and check the mic pins on the radio . Ground one lead and touch each pin for ohms the first one to make noise is the ground. then touch the ground with one lead and touch the next pin and the next . now if there is any left over wire on the plug you can rewire it , then go from there.
Mar 25, 2013 | Radio Shack 40 Channel Cb Radio Model...
TRC-481 No sound
test the internal speaker to see that sound is indeed getting to it.Hook an external speaker to it and see if that works.you just may have to change the speaker but it could be more than that. Do thisfor now then repost as to what you did and whether it worked or not because there is more problems and they are internal. Just go with this for now and if it doesn't work you may have to get it to a tech to repair it.
Jan 10, 2013 | Radio Shack Trc-481 Cb Radio
Radio shack trc-502 cb radio
YOU CAN GET SCHEMATICS FOR THAT MODEL
I JUST LOOKED IT UP FOR YOU........THE BOOK IS SAMS PHOTO FACT...WEBSITE IS
WWW.SAMSWEBSITE.COM
THEY HAVE EVERY CB RADIO EVERY MADE
GOOD LUCK
Jun 22, 2008 | Radio Shack TRC-503 CB Radio
No sound on cb radio
do you get any other sound from the speaker?
check squelch settings
does external speaker work?
If yes - internal speaker is bad
If No - either the Audio Amp chip is bad or the external speaker socket is bad
Jun 01, 2008 | Radio Communications
Galaxy Radios DX-99V 40-Channels Base CB Radio Logo
928 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
