Question about Garmin eTrex GPS Receiver
Garmin etrex GPS
Can the Garmin etrex GPS (the yellow one), be changed to read the bearing in mils instead of degrees?
  • 3 Answers
Go to Setup > Units > Angle and then select Mils
Posted on Oct 23, 2008
  • 64 Answers
If it is posible to, which it should be, go to menu, then setup, then units. Use the position frmt field, your best bet. Hope this helps!
Posted on Jul 26, 2007
SOURCE:
A good software programme for putting maps onto a garmin etrex legendhcx
Try an Old Garmin "Mapsource" version and maps data with very low quality. I read somewhere that new versions of mapsource can't load map to Legend types
Oct 02, 2011 | Garmin eTrex Legend GPS Receiver
When I enter the lat and lon corridinates from the Garmin ETrex legend into google earth they seem to be about 50 miles off.
Make sure you are using the exact same format for both. Degrees and minutes are not the same as decimal degrees.
May 30, 2010 | Garmin eTrex Legend GPS Receiver
Consistent error entering garmin etrex coordinate in google earth
Consistent errors are usually projection or datum related. If you are taking coordinates collected in one projection and displaying them in your GPS in another, you the points will offset. I'm not talking about the decimal degrees 00.000n 000.0000w vs 00 00 00N 00 00 00W. I'm talking about the geographic model to represent the surface of the earth. Google Earth generally uses a geographic projection with WGS 1984 or WGS84 Datum. Make sure you are using the same settings on your GPS.
Apr 09, 2010 | Garmin eTrex Legend GPS Receiver
My owner's manual and reference guide was "drowned" while fishing. I need another one for my Garmin eTrex Legend personal navigator.
hi,
This should be the manual your looking for:
Garmin eTrex Legend Manual
This is a pdf file so you will need adobe or foxit to read it, I;m sure that most pc's come with adobe on them though.
I hope that helps..
Mike
Sep 01, 2009 | Garmin eTrex Legend GPS Receiver
Garmin Etrex Legend
Setup > Position Format > Page 44 of your manual.
Oct 18, 2008 | Garmin eTrex Legend GPS Receiver
Garmin etrex screen too dim to read
I have an older Garmin 12XL and suddenly the screen turned very dark. I tried replacing the batteries and let the GPS rest for a week so the internal lithium battery could re-charge. But that did not work. I just got an email from a friend who had the same problem... it turned out that his unit had changed the screen contrast setting all by its' self.
This may not be the cause of your problem but it's worth trying... go into your "Settings" menu and reset the contrast and see if that cures the problem. Good luck.
Sep 22, 2008 | Garmin eTrex GPS Receiver
Grid bearing
If you press in the control stick, it will make a waypoint at your location and you can see the co-ordinates. The numbers can be displayed in various ways, all depends the settings you have used in the Etrex.
Your bearing will be on your Navigation Page.
http://www8.garmin.com/manuals/eTrex_OwnersManual.pdf
Feb 22, 2008 | Garmin eTrex GPS Receiver
How to change datum settings on Legend eTrex
garmin legend has the datum settings in the system settings menu, under UNITS http://www8.garmin.com/manuals/eTrexLegend_OwnersManual.pdf search for datum hope this helps
Aug 09, 2007 | Garmin eTrex GPS Receiver
Garmin eTrex GPS Receiver Logo
237 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
