Question about HP Photosmart D7160 InkJet Printer
Error 0xc19a0024 printer won't print, fax,copy, scan just sits there. I called 'tech support" to find out what was wrong but I couldn't get past the guy on yhe phone. He kept telling me it would cost $35.00 dollars to talk to a tech or he could send me a new piece of **** printer for three hundred something dollars to try for ten days and then send the old piece of **** back. so I tried to fix it by pulling off the ribbons on the right side and restarting it but broke the connector. now the printer is shot but at least i'll never have to deal with those ******** at hp again!
  • 4,041 Answers
Ok try this link
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
Black ink does not print when printing any document. Color works fine. I installed a new black ink cartridge but have the same problem.
You can find a program on the web , HP PRINT & SCAN DOCTOR, it's from Hp , download it and run it , perhaps it will tell you what's wrong
Oct 29, 2014 | HP Officejet 4620 e-All-in-One Printer,...
How to clear memory in a mp c5000 macine
There are many counters in this machine. Jam, Error, Feed, All, Memory, Service Codes etc, that are located in the service software of the machine. If you don't know what each one does you can end up doing more harm than good by wiping out the wrong ones. Best to call a trained tech.
Aug 14, 2014 | Ricoh Aficio Mp C5000 Color Copier - 129k...
Error message
low heat does not allows u to print , wrong error
May 07, 2014 | Samsung SCX4826FN AllInOne Laser Printer
Won't scan, error message -scanner door is open
Simple solution. I just had the same problem. Make sure the top cover on the left side is snapped in. It wasn't obvious that it was open. They should probably give a better code because it is not the scanner door that is open.
Apr 16, 2013 | Samsung New-scx-3405fw Wireless...
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
LSU Error keeps showing
LSU stands for Laser Scanner Unit. Depending on the model this should come up only if the services used required scanning such as copy, fax sending, scanning.
nevertheless if this is a continuous message you might need to check the connectors within the scanner which I advise an field call.
Apr 30, 2010 | Xerox WorkCentre M20i All-In-One Laser...
HP Photosmart 6180: error code:83C00020?
I cannot get the unit to work at all, it will not turn on or off. On the display screen I get the error message 83C00020 and the memory card light continues to blink on and off. I will not print, scan,fax or copy. I cannot override, I have tried the # and 6 reset but to no avail. I have called tech support and they said it was a 'hardware' problem that could not be fixed at home. Of course, they wanted to sell me a new printer!?! Any suggestions? I am stumped and frustrated.
Nov 18, 2009 | HP Office Equipment & Supplies
Cant copy from web to home copier what am i doing wrong??
Usually the format is the problem,I usually take a screenshot,paste it to paint,then print from there.Or copy and paste the info to wordpad and print from there.
Sep 20, 2009 | Dell A940 All-In-One InkJet Printer
Won't print
The printe will not scan or print. When I fax documents it is recieved witha balck shadow in teh background. I get error 2200 when I try to print or scan.
Apr 03, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
HP Photosmart D7160 InkJet Printer Logo
974 people viewed this question
Seeker5211
Seeker5211
