Question about Brother LS-2125 Mechanical Sewing Machine
Sewing straight lines...
My machine is only a couple years old, but recently it began bunching up thread on one side when I sew straight, simple lines. It seems like something between the spool of thread and the needle is loose and not keeping the thread taught, but I don't know much about how sewing machines work, so I don't know where to start to fix it. Any help is appreciated! Thanks!
  • Tricia Cox Aug 03, 2007
    Hello MakikiChris. Thanks for the link. I read through it and the problem I was having seemed a bit different. I recently took a few panels off my machine though to try to see what was occuring, and it has worked fine since then, so if it starts up again I'll re-check the points mentioned in the post you sent me.
    Thanks for the reply!
    Novelist:
    Scholar:
  • 84 Answers
Hi Tomar....please click on the URL below to begin the healing process amen... Please update your post if you cannot resolve your issues...good luck my friend. http://www.fixya.com/support/t162553-underthread_going_crazy
Posted on Aug 02, 2007
  • V. Chris Suehiro
    V. Chris Suehiro Aug 03, 2007
    Hi Tomar...Although "I missed the boat"...Thank you so much for taking the time to inform me of your success.
6ya staff
SOURCE:
I have a Singer 2263 which is old but not used often. I am making aprons for Christmas, I made 3 and all the sudden the bobbin started bunching together. What can I do?
hi Sue.
Why does my bobbin thread keep bunching up? Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimes thread bunching can be caused by something as simple as the tension dial being inadvertently turned.
Sewing Machine Thread Bunching Up Here Why .
if you go to this link a little pop up will come up just close this down.
or try this one.
How to Fix that Tangled Nest of Bobbin Thread Under Your Sewing
or read up more at this link.
Why does my bobbin thread keep bunching up Google Search
Dec 13, 2017 | Singer Sewing Machines
My Singer 3232 Simple Sewing Machine now almost two and a half years old began to loop while I sew. Why and what can I do to remedy that, please help me.
Install a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Loops gone!
May 25, 2017 | Singer Sewing Machines
Thread bunching up on under side
try rethreading the machine top & bobbin
check to see if the thread has come off the thread take up lever
try changing the needle
also make sure the needle & thread & fabric are compatable
Mar 10, 2012 | Sewing Machines
When I use my Singer model 1120 for sewing straight lines, the thread bunches up underneath. What is the problem?
Be sure that the machine has been cleaned and oiled. Check to be sure the machine is threaded correctly. Check to make sure the bobbin was wound properly.
Oct 31, 2011 | Singer 1120 Mechanical Sewing Machine
How do I set the tension on the White Sewing Machine Model 1599? I am trying to do a straight stitch but the thread is bunching up on the bottom side of the fabric.
You can download the manual from the Singer sewing machine web-site. Go to customer support/ product manuals/ and enter 1599. You'll then be able to download a pdf of the White sewing machine manual for free!
Oct 29, 2010 | White Sewing 1521
Stitches are gathering on backside when sewing on patches
This is caused by a bent needle. Try a different needle that is straight. When they get the slightest bed in them the stitching will end on the back side only
Apr 14, 2010 | Brother LS2020 Sewing Machine
My new sewing machine, just opened to use, is bunching thread on the underneath or bobbin side when I attempt to straight stitch. What is causing this to happen. Thanks.
re thread the top and bobbin threads
after pulling up the bobbin thread pull both threads to the back and hol them when stitching the first few stitches
with out holing the threads the machine will pull the thread into the machine and bunch the thread
Aug 24, 2009 | Kenmore Sewing Machines
Brother LS-2125 Upper Thread Snapping
I had the same problem and it was so frustrating! It was happening to me because I wasn't using the right size needle. Go up a couple of needle sizes and see if that helps.
Feb 12, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
73 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
PHYLLIS SMITH
Level 1 Expert
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
