Question about Maytag Neptune MDE5500AY Electric Dryer
I have 8.8. coming up on my drying and it has stopped.
I unplugged it for a bit, then plugged it back in. It still comes up with 8.8. Can you help please?
  • Anonymous Feb 05, 2009
    I just now fixed mine by putting a heating pad on the LED display for about 10 minutes. YEA!!!! Good luck. Our power has been out for 7 days...same thing happened this fall when we were w/o power for 8 days.
  • boater657 Feb 08, 2009
    I had this same problem today. Magtag tech support had no answers for it. I found the heating pad solution shown here. I thought it was a joke. But.. I tried it and it works! The dryer is running just fine now.
I also had the same problem after a power outage. Why would you put a heating pad on it? Well, I tried the heating pad...and IT WORKED!
Posted on Feb 07, 2009
How do I get the open door chime to stop on Kenmore Fridge?
I had this problem also. My problem was that the drainage tube that keeps the refrigerator compartment dry was plugged up with the foil backing used in the freezer compartment. This foil backing is used to line the closed cell foam which insulates the defrost heat fins from coming in contact with the plastic back panel. It took a service call from a local repairman two times to unplug the line. We peeled off the foil lining which was the source of the plug.
This solution stopped the "door open"/"instant freeze" cycle sound. My fridge is about 6 years old.
Hope this helps. Best wishes!
Jul 23, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Why would my fuel gauge stop working
fuel sensor in the tank may be warn you can test to see if it is that by turning on and off the ignition if the gauge jumps. then it is the sender in the tank. under the carpet in the boot is a cover open this and you are at the tank it has a screw on cap and 4 wire on a plug going to it, remove the wires and the pipes for the pump and push to one side when you do this make sure you use a cloth as fuel will come out, before any work is done further it must be dry from fuel so leave it for awhile till dry. then undo the screw cap, ( dont do on a full tank of fuel) the top comes away a bit and unplug the wire on the other side this will give you more rum to get the sender out , it is clipped in at the top just squeeze the top and pull out, replace with new one and make sure its in place and dont move, this is the hard part now you have to make sure the wires dont get in the way when you have put the cap back on run the wire around the fuel line and up to the fuel top and plug the wires back in and re put the tank back to the way it was, it should be all working now.
Mar 22, 2013 | 2007 Volkswagen Jetta 2.5 Sedan
My whirlpool gas dryer is having problems with heat. My clutch went bad on my washer and the clothes were coming out very wet. Then I noticed my dryer wasnt drying anymore. I have watched all the repair...
Check your dryer vent on the outside of your home first. There should be as much air coming out as comes out if you unplug the vent from your dryer and feel it there. It sounds like you have a clogged vent.
May 16, 2011 | Dryers
Beeping won't stop and the F7 error code appears on the monitor
You may have got water into the control panel or cooktop causing an electrical short. Hopefully if you give a few days to dry out and plug it back in the code will be gone.
Sep 10, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
TV will not turn on.
hello..i think you have very big problems inside on you're TV you need a Electronics Technician to see inside the real problem.my tips is located in Power Supply Regulator..Can i know what kind TV Model???thanks
Apr 23, 2009 | Televison & Video
Drying clothes & the dryer just stopped & won't come back on
This is likely the thermal fuse on the heating element. You can check it with an ohmmeter. Also clean out your venting, as this often causes it to blow. Hope this helps!
Mar 09, 2009 | Maytag PYE2300AY Electric Dryer
1999 cavalier battery light coming on but has new battery
start car ,unplug 1 of the batt. cable dont let cable touch anything if car stops doesnt look for alt. check all connections at alt. are good
Feb 25, 2009 | 1999 Chevrolet Cavalier
My Sony Vaio Laptop PCG-661R not booting
unplug from power and remove battery and plug back in.
Dec 12, 2007 | Sony VAIO PCG-K25 Notebook
Maytag Neptune MDE5500AY Electric Dryer Logo
65 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
