Question about Faberware FSB100 Work Top Blender
Plastic jar broke.
Where can I buy a replacement plastic jar for my Faberware FSB100 blender?
I decided to replace the entire blender and I bought a new one online.
Posted on Jan 29, 2009
I need a replacement blender jar for my Toastess juice extractor and blender :400 watt blender, wher can I get a replacement jar
Try here:
http://theconsumerlink.com/Toastess/list/TOASNEW/17
This is the official Toastess site. If the offered blender jar does not fit your model you may have to search on the secondary market.
Trust this is helpful.
Mar 10, 2012 | Toastess Blenders
GE single serve blender 898679--need replacement plastic gasket for grinding jar. I am told by Walmart, where I purchased it, that I need to return it. I don't want to return it. The blade chewed up the...
I had the same issue. i took the gasket from the other blade to use with the blade i use everyday. one trick is, don't remove that gasket to clean it but make sure it stays in there. Just soak it and scrub it good, to make sure it stays seated in there.
If the gasket comes loose while you are grinding, the lid will come loose in the base and sometimes causes you to not be able to get the jar from the base. you have to turn the jar the opposite direction to get the lid to tighten up, then you can remove the jar from the base.
I am trying to get replacement jars since those plastic nobbies that run the blender have broken off. It is down to one of 3 nobbies, so it can't be run anymore. I mght just have to buy a brand new blender but it seems so wasteful.
Mar 15, 2011 | GE Blenders
I broke something when I was putting the jar on my bosch MMB1000 blender and then it didn't start after that. I thought that I had broken the safety and when I open it up I saw a small broken plastic thing...
Without seeing the part that is broken it is hard to say what exactly the problem is. But it sounds like it is one of the safeties. Look on the bottom of the jar to see if you can see where the plastic broke off of. If not then the plastic is probably the safety inside of the lower part of the unit.
Jan 07, 2011 | Bosch MMB1000 Work Top Blender
Part "i" , the plastic(nylon) tooth part on my Braun PowerMax Blender, type 4184, broke and I need to find a replacement part. The Braun Service website was useless. Can you help? ...
www.smallappliance.com. you can order a new blender blade which has the white nylon teeth or you can order the coupling which is the black teeth that the jar sits on. NOTE: the black one is easy to replace, but getting the screws out of the base is the hard part.
Jul 02, 2010 | Braun MX 2050 PowerMax Work Top Blender
KSB5600BO kitchenAid blender blades broke and l am looking to replace them but I can't find the right parts. Do I need to just by the whole Jar assembly?
You don't need to replace the entire jar assembly. Have you tried to contact Kitchensid. They make high quality appliances and will probably send you new blades for $0.
Apr 19, 2010 | KitchenAid KSB560 5 Speed Blender
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
GE Blender Jar loose rotator
Remove the bottom clean the unit fully. Add the bottom blad assebly and this will fix your problem. The "sooty" is plastic shavings. Take note that the fitting were the "jar" connects to the motor that this is not wearing away. The unit i have broke and i am unable to find a replacement blade assembly.
Apr 04, 2009 | Blenders
Replacement glass jug?
I will buy the blade set from you? I will return....
Nov 14, 2007 | Bosch MMB2000 Work Top Blender
Need a new plastic pitcher for our villaware 5787 Smoothee
Hello Guest - Would you have the number? I can't find it anywhere...thanks!
Oct 19, 2007 | VillaWare 5787 Double Smoothee Work Top...
Replacement jar
I have the double one two and need to replace both of the pitchers. Cant find them anywhere
Jul 17, 2007 | VillaWare 5787 Double Smoothee Work Top...
Faberware FSB100 Work Top Blender Logo
75 people viewed this question
Top Faberware Blenders Experts
eyecam
Are you a Faberware Blender Expert? Answer questions, earn points and help others
